Question about Samsung HLP4663W 46" Rear Projection HDTV
Picture is much too big
I have a Samsung HLP4663w and the overscan on it is too much to take now. I adjusted the image's V and H values but can't seem to find a value to shrink the image slightly. Is there a way to fix this overscan issue?
    Champion:
  • 217 Answers
Try the P-size button on the remote control
Posted on Aug 03, 2008
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
My tv scren has been shrink, how to return it to the regular size. thanks
Try:
Main Menu - Picture - Screen Settings - 16.9 Overscan - ON
This mode displays the image for 16.9 aspect and when on enlarges the image to hide the edge of the image.
Good luck.
Sep 26, 2014 | Samsung Televison & Video
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
I have a samsung series 5 530 lcd. The picture is to big for the screen. I've tried everything in the manuel. help
Also, Check the picture menus for a pixel-to-pixel or 1-to-1 mode. This allows you to watch an HD signal with no overscan.
Jan 10, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
michtech
Feb 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Connection to MAC Mini
No changes can be made to the picture size on the panel. Most PCs have a facility to reduce the size by software means to correct this sort of problem (for example in 'Display properties'). As for the Mac; since it's not my area of expertise I can't say for sure but I'd be suprised if it didn't have this feature.
Nov 08, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Samsung HLP4663W 46" Rear Projection HDTV Logo
308 people viewed this question
Henry  Thomas
Henry Thomas
