Tevion TEVHS4 My Tevion TEVHS4 VCR/DVD player works just fine apart from the rewind function on the VCR side. When iI attempt to rewind a tape the machine does engage rewind but only moves very slowly and then stops within a few seconds.I have not attempted to open it up or anything just yet. Can any of you guys shed any light on this problem ? I am guessing that something is telling the VCR that the tape is fully rewound when it is not. Please assist if you can, Best Regards from the UK Graham.
  • 2,130 Answers
How does the fast forward work? There is a device in a VCR called an idler tire, which is a flat disc that lays horizontal and has a rubber tire around it.
The idler tire is on a pivot and it pivots between the tape sending reel and take-up wheel depending on whether you are in rewind or fast forward.
I suspect that the rubber is worn on the tire and that the wheel is slipping. You might also have some worn belts as well.
The idler tire & belts can either be replaced or re-gripped using a re-grip solution that roughens up the very top surface of the rubber.
The problem will be the worst when the tape is at the end and all the tape is on one of the reels. This causes the most drag or resistance and if the idler tire is slipping, the reels will go slow and the deck logic will sense that and then stop.
You can find generic belts and idler tires at www.mcmelectronics.com
Please let me know if I can be of further assistance to you.
-Jim
Posted on Jul 13, 2008
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
VCR eating tapes when attempting to rewind
VCRs are so cheaply priced these days that it's not worth the time and trouble to fix them or have them repaired. If you fix one worn or slipping belt, another problem isn't far behind.
Feb 26, 2007 | Symphonic WF802
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
