Samsung washing machine won't complete cycle
I have samsung washing machine having same problem, not completing cycle, it stopped in the middle and then we have to off and on agian to complete the cycle
  • avro_arrow10 Nov 12, 2008
    i have a maytag top load washing machine. during cycle it stops at rinse. i try to restart but goes all the way back to beginning and rewashes again to the same point?
  • Anonymous Mar 08, 2009
    I have a samsung front load washer and it quits in the spin cycle after trying to find a balance over and over, this happens at least three ous of five times
  • 868 Answers
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Posted on Jul 13, 2008
Why does my samsung washing machine only fill water for a couple seconds and then stops?
SAMSUNG CUSTOMER SUPPORT PHONE NUMBER:
1-800-726-7684
M-F
9-9 EST
Nov 14, 2014 | Washing Machines
Flashing light
If the cycle completes and your clothes are clean this is no issue. If the former does not happen. Then return to the store and get another machine.
Jan 24, 2014 | Samsung Washing Machines
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
In the middle of a cycle, it has stopped and is
nf is NO fill
i would check your cold water line
take it off the machine and check the screen as well
no fill means it is timming out waiting for water
Oct 09, 2009 | Samsung WF337AA Front Load Washer
Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Jul 07, 2009 | Samsung WF337AA Front Load Washer
Washing machine does not finish complete cycle
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Jul 06, 2009 | Samsung WF203ANW Front Load Washer
Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Apr 15, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
2,052 people viewed this question
Top Washing Machines Experts
