Question about Canon Cameras
Hi I needed to change the batteries of my PowerShot A540 and foolishly did this without turning the camera off first. It is now 'frozen' in the act of trying to retract the lens. It won't turn on. All that happens when I try to turn it on is that the green light on the top briefly goes on. What should I do? Thanks. Mike Workman
    Guru:
  • 1,894 Answers
Does this show any lens error ?
please try pushing the lens assembly gently with hand
Posted on Jul 13, 2008
  • dewan nafees ahmed Jul 13, 2008
    actually that is a mistake of changing the batteries with out turniig off.
    this would make the camera unit to confuse between its ON and OFF states.
    try turning ON the camera again and again.
    and try gently push and pull then lens with your fingers(don't be hard)
    if this works you may be lucky.
    else you will have to take it to a service only.
    you don't have any other option here in this case.
    if you take it to service center they will dis-assemble he unit and reset the lens assembly and flash the camera memory and then make the unit work again.
    thank you
    hope my solution is clear.
    dont forget to accept the solution if you are OK with it.
    good luck.
I bought my camera in july 2006 - recently it runs
I´ve got the same issue. If you use the batteries that were in A540 in another camera, does it still work?
Jan 11, 2010 | Canon PowerShot A540 Digital Camera
My camera is a powershot A540 dropped it
1. Try to fully charge ur batteries, and then check the camera.
2. If above don't works, it's a hardware problem due to that shock! contact ur dealer/service center!
Tell me if it helps...tc! :)
Jan 02, 2010 | Cameras
Problem with my rechargeble battery with my Canon Powershot A540.
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Sep 09, 2009 | Canon PowerShot A540 Digital Camera
Flashing indicator lights when treying to power on my a540
Hi there, I can help you with that. Do this:
Turn the camera off.
Take out the batteries for 5 minutes.
After 5 minutes, put the batteries back in (or get a fresh set).
Then turn the camera back on.
Let me know if that helps or not with a comment. If it helps, feel free to rate my answer accordingly. Thanks for coming to FixYa.
Rob
Feb 22, 2009 | Canon PowerShot A540 Digital Camera
Change resolution on Canon PowerShot A540
Follow the instructions in the "Changing Recording Pixels and Compression" section of the advanced guide (page 31 in my copy). If you need the manuals, you may download them from here.
Dec 25, 2008 | Canon PowerShot A540 Digital Camera
Problem with Canon digital camera PowerShot A540
This has nothing to do with removing the battery.This problem is common in digital cameras especially canon.There are a few things you can try
1: Place the camera flat onits back on a table, pointed at the ceiling. Press and hold the shutterbutton down, and at the same time press the power-on button. The ideais that the camera will try to autofocus while the lens is extending,hopefully seating the lens barrel guide pins in their slots.
2:Blow compressed air in the gaps around the lens barrels with the ideaof blowing out any sand or grit that may be in there jamming the lens.Other variations include blowing with a hair dryer in “no heat”setting, or sucking the gaps with a vacuum (careful with this one).
And the third fix. Well there is some potential of damagin the camera but may people have reported to have got it working by a systematic whacking procedure.
http://www.fixya.com/support/t240817-camera_error_e45
Jul 13, 2008 | Canon PowerShot A540 Digital Camera
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 27, 2008 | Canon PowerShot A540 Digital Camera
Green Light Turns on, Sound of turning on, lens comes out, but then goes back in a turns off. . .It's not the batteries. PLEASE HELP ME!
Note that some batteries just don't hack it in digital cameras, even if new. This is especially true for those "super heavy duty" batteries:
http://camerarepair.blogspot.com/2008/02/simple-fix-for-digital-cameras.html
OK, so it's definitely not the batteries. A few of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
May 24, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital...Problem
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Jan 01, 2008 | Canon PowerShot A540 Digital Camera
Powershot a540 "cannon"
Dec 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
18 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
