Question about Dell Inspiron 2200 Notebook
Dell Inspiron 2200 monitor issue
Ok here is my issue the bottom half of my monitor is a barcode looking blue and purple screen that obscures viewing the screen where-as the top half is normal....wen i shake the computer a bit it all clears up for a minute then it slowly returns.....a little help?
    Genius:
  • 2,028 Answers
Could be that the monitor is going out, but it sounds more like a connector has worked loose or corroded and isn't making a good contact. Check and clean the screen connection, screen to inverter, and screen to motherboard.
Posted on Jul 15, 2008
Inspiron turns on but not monitor
That is good, it proves the problem is in the laptop display, the most likely issue is the inverter board, "located just below the LCD screen" the other less likely is the backlight just behind the LCD display.
Apr 06, 2012 | Dell Inspiron 2200 Notebook
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
How do you get aero to work on a dell inspiron 2200?
right click on desktop...personalize...window color and appearance...At the bottom of the Windows Color and Appearance window click “Open classic appearance properties for more color options” ...Look at the scroll list and select "Windows Aero" as the new scheme ...click apply and then ok
Feb 03, 2010 | Dell Inspiron 2200 Notebook
I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
Dec 25, 2009 | Dell Inspiron 2200 Notebook
Monitor comes on very dim, I can't see
click your "fn" key and then press the brightness key on the keyboard (it will be a blue or green "sun")
If this does not work, plug an external monitor to the laptop, if the screen is good on the monitor, your LCD display panel is shot.
Mar 21, 2009 | Dell Inspiron 2200 Notebook
Wireless router problems
Try right-clicking on icon of monitor at bottom of screen. Click on "repair" and follow directions. This has worked for me many times.
Dec 22, 2008 | Dell Inspiron 2200 Notebook
Screen wont light up
Try connecting an external monitor to the Dell Inspiron 2200. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor display is dark, problem is with either the video card or motherboard located inside your laptop.
Here’s a link to disassemble the LCD unit: http://support.dell.com/support/edocs/systems/ins2200/en/SM/display.htm#1084976
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 18, 2008 | Dell Inspiron 2200 Notebook
Dell inspiron 2200 is not powering up after being switched on, its on black screen! help
The most probable cause of failure is the memory sticks on the computer. Follow the troubleshooting steps given below and you would be able to get the system up
http://tinyurl.com/5gmvww
Thanks
Proton
Donot forget to rate the solution if it was helpful or resolve your issue
Jul 26, 2008 | Dell Inspiron 2200 Notebook
I am using DELL Inspiron 6000 laptop.Suddenly half of the screen of my laptop is showing multi color lines. I am able to view only the upper half of the screen. Please suggest me what needs to be done
attach an external monitor to be certain the video card is ok,
next
Re-seat the video card cable to the lcd screen,
dell site explains how to remove top and keyboard.
your real issue may be the cable itself or the lcd screen.
May 06, 2008 | Computers & Internet
Dell Inspiron 2200 Notebook Logo
116 people viewed this question
Alun Cox
