Question about Toshiba Computers & Internet
We are tring to connect to a wireless internet connection and we cant. it says we need to turn on the wireless networking radio? how do we do that? we have a toshiba satellite laptop. thanks
    Scholar:
  • 43 Answers
There should be a wireless button or switch on the perimeter of the laptop. Either this or a function key on your keyboard that you need to depress while clicking another key that has a wireless picture icon on it.
If you hit the right switch you should get some kind of notification either on the display or with the enabling of a new wireless light on the laptop.
MO
Posted on Jul 13, 2008
Outlook and IE can't find WiFi connection. I can connect to a wireless network, but I can't get IE or MS Outlook download from it.
First of all turn the wireless radio off on the laptop, then go to the modem and the wireless router and turn them off for 2 minutes.
Turn them back on and wait a further 2 minutes for them/it to reset.
Now go to your laptop and turn the wireless radio back on again, re-connect to the wireless signal and see if you can access the net. If you can then you should have no further problems retrieving your emails or accessing the internet.
Please feel free to post back if you need to.
Good luck.
Jan 08, 2010 | Acer Aspire 5050 Notebook
Aquiring network address
Hey there,
in connecting wirelessly to the router, we need to make sure the encryption on the router.
Access the router setup screen, check the IP address first of the computer.
Open IE type there 192.168.1.1 username is blank and password is admin.
once it is on the setup screen checked the wireless tab and look for wireless security, verify it and try to connect again.
in your wireless computer, right click wireless connection and go to view available wireless network, try to connect - input the network key if in case it is not asking you for it, click the changed the order of the preferred networks and then removed all the preferred networks there, then try to connect again and you will now be asked for a network try to connect and you should be connected then.
Jun 24, 2009 | Linksys WRT160N Wireless Router
Tring to use a wireless n usb on a g router
Make sure to use the wireless utility of your wireless N adapter and not the Windows Wireless Zero Configuration utility. You can also change the wireless channel of your router to channel 11 and power cycle the router by turning it off for 30 seconds then turn it back on. Try to connect again. Make sure firewall on your computer is disabled.
Apr 15, 2009 | Belkin (F5D7230-4) Router (587009)
Connect itouch to internet
From what it sounds like, you are working in a Windows environment. What you are trying to do is bridge your wireless ad-hoc network with your wired network connection. Windows does not support this method of connection even though they have the option for "allow other network users to connect through this computer's internet connection". That would only work if you had two ethernet cards in your system, and that option bridges one ethernet port with the other. It doesn't support bridging to your wireless adapter.
Most laptop wireless cards do not support an "infrastructure" mode, which would turn your notebook into a mobile router. Instead they create an ad-hoc network completely separate from your wired network. There are some commercial pieces of software that can bridge the two, though I've never been able to make them work.
The easiest route would be to go to Target or a local electronic store and pick up a wireless router. You would take the ethernet connection from your laptop and attach it to the router. Then your laptop and iPod would both connect to the internet through the router.
Mar 29, 2009 | Apple iPod touch Second Gen (8 GB,...
Wn121t won't connect to the router
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Aug 18, 2008 | NetGear WN121T (WN121T100NAS) Wireless...
Psp
First you need a wireless connection[home,coffee shop,hotel,etc]go to settings,scroll to network settings,click x,infastructure mode click x,new connection,scan follow prompts then go to internet browser select connection
Aug 09, 2008 | Sony PlayStation Portable (PSP) Console
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Jun 19, 2008 | Belkin (F5D7231-4) Wireless Router
Cant get wireless internet to work
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections
Click window opens. Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
