Question about GPS
Resetting initial info
I messed up trying to enter the inital information during setup how do i go back to that area to enter my info
  • Faithwhit Mar 01, 2009
    I cannot change the language from Spanish to English - can anyone help?
I bought this in the US and will use it here if I can get it off Canada and on USA, how do I do this
Posted on Nov 10, 2008
  • 3 Answers
In the simplest formats there will be an option for editting the information. It would be helpful to know what unit you are using and what information needs to be changed.
Posted on Jul 13, 2008
Tip
BellSouth AT&T Motorola Modem Red Light/s, No Internet
Modem, Router and PC
1. Press and hold the reset button on the back of your modem for 10 seconds to fully reset your modem to initial factory defaults.
2. Wait for the modem's Power and DSL LEDs to turn solid green.
3. Open your computer's Internet browser and your modem should launch a mini-setup routine. Enter your FastAccess DSL username in the format of yourusername@bellsouth.net, enter your FastAccess DSL password and confirm your FastAccess DSL password and click next, then there will be an "Auto Calender Update Configuration" page where you will set the auto update info and timezone info so just enter the info and click next.
4. Your browser will refresh the page and say everything is ready to go, this may take a few moments. When this is complete type 192.168.1.254 into your browser's address bar and click on the "Broadband DSL Line" tab, then on the right, click on Connection configuration.
5. Change the Protocol from the dropdown box to Bridged Ethernet Mode, and then click on Save and Restart Connection.
6. Open your computer's Internet browser again and type in 192.168.1.1 into your browser’s address bar. In the Internet Setup, change the Internet Connection Type to PPPoE and enter your FastAccess DSL username in the format of yourusername@bellsouth.net, enter your FastAccess DSL password and click on Save Settings.
7. Close all windows and restart your computer. Your internet should now be working.
Modem and PC
on Jul 24, 2010 | Computers & Internet
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
Sep 26, 2013 | HP LaserJet 2840 Printer
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
How can I perform an NVRAM initialization with my HP CM1015 MFP
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jan 13, 2011 | Panasonic SC-HT730 System
How to hard reset a 1312nfi
This reset will change user and network settings Before performing this reset it would be advisable to print some information pages to retain any settings that you might want to restore.
Configuration Page
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Configuration report, press OK.
Menu Structure
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Menu Structure, press OK.
Network Report
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Network Report, press OK.
After printing these reports it will be safe to perform an NVRAM initialization to hard reset the product. Follow these steps.
1. Turn the machine off.
2. Press and hold the right arrow and cancel (x button) while turning the machine on.
3. Release both buttons when Permanent storage init. is displayed.
Once finished resetting the machine will return to Ready.
Jun 16, 2010 | HP Laserjet CM 1312NFI Color Printer
Im trying to reset the internal clock. My father messed with settings so therefore games wont play on certain date. Such as PGA Tiger Woods 2005 RTE Calender
first do this
Settings > System Settings > Restore Default Settings
Restore the system software to its default settings. Follow the on-screen instructions to perform this operation.
After the operation has been completed, the initial setup screen will be displayed. Follow the on-screen instructions to perform initial setup of the system software.
Notices
  • When you perform this operation, the system software and the information for the user who is currently logged in will be restored to the default settings. Be careful when performing this operation as changes to the settings cannot be undone. Data loss or corruption is the responsibility of the user.
  • When multiple users exist on the PS3™ system, the information that is managed by users other than the user who is currently logged in will not be restored. Information that may be managed by other users and cannot be restored include the following:
  • - Sign-in ID and password for PlayStation®Network
  • - Bookmarks, history and settings added under in_browser.gif (Internet Browser)
  • - Information about the image set as wallpaper under in_photo.gif (Photo)
  • - Terms added using in_setting.gif (Settings) > in_console.gif (System Settings) > [Add/Edit Term], or predictive terms "learned" by the on-screen keyboard
  • - Keyboard or mouse settings under in_setting.gif (Settings) > in_peripheral.gif (Accessory Settings)
  • - Voice changer settings under in_setting.gif (Settings) > in_peripheral.gif (Accessory Settings) > [Voice Changer]
  • - Theme, color, background and font settings under in_setting.gif (Settings) > in_themeset.gif (Theme Settings)
  • Do not turn off the PS3™ system during this operation. If the operation is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • During this operation, the power button on the system front and the PS button on the wireless controller are not active.
  • You cannot use this feature to go back to an earlier version of the system software.
if this nor work you have to hard reset but take all backup first inexternal hdd or pen drive.
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your problems.
Jan 28, 2010 | Sony PlayStation 2 Slimline Console
Do not have user manual and need to run setup
Click Sony Support to download user manual of KDL-32XBR6
Manual has detailed info about initial setup.
Mar 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Iphone 3G Mail Account Set-up
can't send or recieve on the iphone
Jul 14, 2008 | Apple iPhone 3G
GPS Logo
103 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
