Question about Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator
Ice Maker water keeps running
I have a Frigidaire PLHS269ZEDBZ and the ice maker continues to run.
This problem started when I turned off the ice maker because the ice bucket was full. When I turned it back on, the ice maker continues to run through the cycles. It will fill up the ice tray with water, then the ice maker will immediately run through another cycle and add more water. This process overfills the ice tray and water runs through the freezer and out the bottom of the door.
Any help?
Thanks.
  • 6 Answers
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Posted on Jul 22, 2008
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
Oct 12, 2013 | Frigidaire Refrigerators
Ice maker not working
pour water in your ice maker. when it dumps ice cubes, keep filling it up again.after 5 or 6 times it should start working on its own
Oct 21, 2012 | Frigidaire Refrigerators
Frigidaire Superba Ice Maker not stopping making ice
-Turn the ice maker off. If still leaking and decide not to use the ice maker to make any more ice then unplug the
water valve that let water run to the ice tray. Only the one for the ice. Otherwise you will not have any water at all.
Good luck
Mai
Mai
Nov 01, 2017 | Frigidaire Refrigerators
The ice maker has stopped making ice.
first check the water supply on the ice maker check inlet water solinoid valve then reset the unit by unplugging power cord after a minutes plug the unit and start ice maker see to it that the compressor running.
Jan 23, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
I have a Uline model SP18 ice maker.Recently the ice maker continues to cycle,Filling with water and at the point when it should stop the compresor turns on then off as it continues to turn,starting the...
It does sound as if you may need a new ice maker. Other than that does the compressor come on to keep the ice cold? If so is it making any type of noises beyond the typical hum?
Jun 10, 2017 | U-Line Icemaker
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
ICE MAKER NOT WORKING PROPERLY. ICE WILL FREEZE
See if the fill tube is partially blocked with ice. It's the tube where the water comes into the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jul 12, 2009 | Frigidaire FRS26RLECS Side by Side...
Ice maker over fill, water keeps running
If water keeps running to the ice maker all the time even when it doesn't call for water , the water valve for the ice maker is leaking(located in the back of the refrigerator,bottoom right),but if overflow only when it calls for water(no more than 7 seconds) the problem is in the ice maker control board, you can replace it but it will cost almost as a new ice maker.
Apr 14, 2009 | Refrigerators
Whirlpool ice maker
could be a problem with the ice maker itself or the water solenoid that controls the water.
the ice maker itself controls the solenoid. if there is a stuck contact, then water would continue to run.
if the solenoid has a leaky valve, water would still come in even there is no more power.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Whirlpool GD2SHGX Refrigerator
Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator Logo
550 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
