Question about Pioneer Audio Players & Recorders
Overload error on pioneer vsx-d814 receiver - Pioneer Audio Players & Recorders
5 Suggested Answers
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
smarthome2
  • 1114 Answers
SOURCE: new pioneer vsx-517 keeps going into overload
Fastest way to test is to disconnect all speakers and turn up the vol. If it clips it needs service, then re-connect 8ohm speakers one by one and test until you find the speaker or channel that shorts. Then take that same speaker and hook it up to another channel and test, if it shorts, you know now it is either the speaker or the wire. Now, use a new piece of speaker wire from the same channel that caused it to short, replace the old and test. If it shorts, you've got a problem with the speaker. If your handy with a multimeter, check the resistance at the speaker and you will have your answer. If you are not familliar with a multimeter, just hook up a different speaker where the bad one is and test. It's just process of elimination. Hope this helps
Posted on May 25, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
SOURCE: pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Posted on Feb 07, 2010
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Pioneer receiver vsx d814 amp error
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Pioneer vsx-917-s/-k suddenly says overload and switches off while watching a dvd
pioneer vsx-917-s/-k suddenly says overload and switches off while watching a dvd, listen cd and tuner.
May 24, 2008 | Audio Players & Recorders
Pioneer vsx-d814 will not power on after power surge
Mar 21, 2008 | Audio Players & Recorders
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
607 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
