Vista Service Pack 1
Had no problems with downloading the service pack after 5 failed attempts, but when I tried to install it, I recieved the error code: 0x80070002. Don't know where to go from here? i do not know how to install themes of windows vista on my pc when i download desktop themes which i did notlike
My vista is not instoling / making disc so pleas help me.
regards
rahul
Posted on Jul 14, 2008
Error code 643
Try this for starters:
http://support.microsoft.com/kb/923100/
Basically, it involves un-installing .NET Framework Version 1.1 Service pack
1.
Then download and use (Run as Administrator) the Windows Installer CleanUp
Utility, and remove all references to .NET Framework Version 1.1 Service
pack 1 (only!).
Then reinstall .NET Framework Version 1.1 Service pack 1:
http://www.microsoft.com/downloads/detai…
Then run Windows Update again, to install KB929729.
Jun 25, 2010 | Microsoft Windows Vista Home Premium with...
Tip
How to obtain the latest Windows Vista service pack?
Introduction:
Windows Vista updates are distributed in service packs. Service packs
help keep Windows Vista current, and they can extend and update the
functionality of your computer. This article describes three
step-by-step methods that you can use to obtain the latest service
pack for Windows Vista. However, before you select the method that you
want to use, please make sure that the following conditions are true:
The service pack is not already installed on your computer.
You are logged on to your computer by using a user account that is a
computer administrator.
The computer on which you want to install the service pack is
connected to the Internet.
If you are not sure that all these conditions are true, please see the
"Before you try to download the latest Windows Vista service pack"
section. Otherwise, select the method that you want to use to download
and install the service pack.
Methods to download the latest service pack
Method 1: Turn on Automatic Updates (Recommended for most users)
Method 2: Check for updates on Windows Update (Same as Method 1 but
not automatic)
Method 3: Obtain the latest Windows Vista service pack from the
Microsoft Download Center (Good to use if the computer on which you
want to install the service pack is not connected to the Internet)
Important: Windows Update may not offer the latest Windows Vista
service pack to some users. This issue can occur for several reasons.
For a full list of causes and resolutions, click the following article
number to view the article in the Microsoft Knowledge Base:
948343 Windows Vista service packs are not available for installation
from Windows Update and are not offered by Automatic Updates
on Mar 28, 2010 | Computers & Internet
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
Have trouble installing Vista Service Pack 2. It
check the disk if its not scrached in anyway if your disk is new the it might be your dvd writer,s problem.so the best thing u can do is to transfer your vista into a flash disk probaly a 4G or something then install ur vista through USB.good lucky
Nov 03, 2009 | Microsoft Windows Vista Home Premium with...
Unrecoverable error Code 00000 40149
There has been an issue similar to this seen with people whose windows xp recieved service pack 3, or vista service pack 1.
From what I understand, microsoft has pulled the updates due to issues with their own products. If your system has recieved the service pack, contact MS Tech support to have the service pack update removed.
Dec 08, 2008 | Computers & Internet
Vista
Did you complete the new install validation process? For most, who have a product key and install CD it may still fail, Microsoft or a tech local to you who can phone Microsoft Licensing and actually help you out, even if you ended up with a Pirated copy without knowing it was pirated. See phone number below.
Do you have full administrator privileges? You can right click the link in your menu and from the drop down list select 'Run as Administrator' and this may solve your problem. If it doesn't you do need Service Pack 1 from Microsoft that fixes more issues you wouldn't be the length of the list. If you can't pass the validation procedure all is not lost but you will need to phone MS from the number below and no matter what they can get you running correctly.
This phone number can actually get you free help from Microsoft themselves here:
Phone Support Wait Time: Will vary
Hours of Operation onepixel.gifNo-charge: Unlimited support requests.
(866) 234-6020
According to Microsoft, downloading Service Pack 1 should resolve this problem as well as others only if you've validated your copy of Vista.
The download link for 32bit Vista service pack 1 is here.
The download link for 62bit Vista service pack 1 is here.
Don't know which you have, then you probably have 32bit.
Sorry this isn't an easy How-to Fix It, but the problems with Vista are far ranging. And after the service pack install, the issue will probably go away.
Kind Regards,
Worldvet
May 25, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
