Question about Samsung LN-S2651D 26 in. LCD Television
Dots all over screen
We have had this tv for a year and a half, always been mounted on the wall not moved, it started showing dots all over the screen, if you look close there are colors in the dots.  It does this on all inputs, so we know it's not a cable..  what can be done is this something we can repair ourselves?
  • fiveasone Jul 14, 2008
    thanks for the post, it really strange, if you turn the tv on it looks like the picture might be fine then these dots appear all over the screen. I tried cleaning it with a cleaner we got when we purchased one of our LCD tv's and it didn't do anthing. At first when it started doing this you could watch the tv for awhile then turn it off and turn it on and almost all the dots were gone, now they are always there.
  • Samsung Master
  • 5,568 Answers
If you would spray a coarse water mist on the screen, would it create the same effect?
Or, take a toothpick, wet it, then touch the screen with it leaving a small dot of water; if it looks like the other colored dots and the colors shift when you move you head slightly back and forth, what you are seeing is a lens-effect and changing the angle will alter which individual pixel you are seeing causing an apparent change of color.
It sounds as if some kind of overspray, perhaps of an oily aerosol like Pledge or WD-40 has found its way to the screen.
I'm kind of curious about this one, I don't think it is electronic in nature, please post back if you discover something.
Posted on Jul 13, 2008
Why vertical lines on half of screen after moving Proscan 39" LED TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 14, 2014 | Proscan 32LB30QD 32 in. LCD TV
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
White dots and black on my screen
Are these dots moving with image or stationary under a moving image. This is a key identifier
Jun 23, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Screen damaged in corner
Hi. you can replace this screen but, it would most likely equal the price of a entirely new set. The wall mount is a great idea as well. It will keep the LCD screen in a safe place.
Please rate and god bless:)
Apr 02, 2009 | Insignia IS-LCDTV32 32 in. Television
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Sanyo dp42746 half screen blacking out
http://cgi.ebay.com/philips-plasma-Y-board_W0QQitemZ270262136649QQcmdZViewItem?hash=item270262136649&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Jul 20, 2008 | Sanyo DP42746 42 in. Plasma Television
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Problem with wacthind dvd in full screen and black dot on screen
Not sure I understand the half of the tv and half of the dvd player. Are you saying about mid way of your set is cut off and like the bottom half you have a picture and the top no picture? I can explain the dot, first you can open back of set and maybe take off hole back bezel. Get where you can put your head down in front of C R T's (tubes) and look down in them and see if you see the same thing in one or all three of the tubes. If so this explain the dot. The half problem sounds like vertical is missing. Not sure yet! Need feed back
Aug 10, 2007 | Philips 43PP9202 43" Rear Projection...
Samsung LN-S2651D 26 in. LCD Television Logo
206 people viewed this question
Henry  Thomas
Henry Thomas
