I've never seen cinder block affect wireless signal before. Metal pipes and ducts can interfere as can electromagnetic interference from appliances and ungrounded wires.
If possible, moving it to a location higher up, like a second floor of the home, could help broaden the range. Also, check to make sure that that there aren't any wires grounding out on places they shouldn't be (pipes and ducts).
Aside from purchasing expensive external antennae, moving the router through trial and error is probably your best bet.
the thermostat may be in the wrong location for it to work correctly. make sure its in a well heat vented room and not in a closed low volume room. it you want heat push the "hold" button and set a temp that works for you. when done push "run program" buttom to run what you have set into the program.
hi there i have a instuctions book for a delta orion multigym with a pic of pully and cables if you still looking drop me a line at [email protected] and i'll email you a copy of the layout
matt
i hope you can help me!
i went to change the combination on my locked Samsonite bag and when i closed it it would not open on that number.
i have tried the past number as well as the new one and it still doesn't open. thank you if you can help please it would be appriciated.
Carolyn
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Unless you damage the thermostat in someway, covering it is a non issue.
Because it is an electrical device you will still want to have easy access to it, so don't do anything too permanent!
OPTIONAL:
I recommend that you disconnect this device at the power source (usually its own breaker/fuse) just to be safe.
