Question about Pioneer AVIC-D3 Car DVD Player
Pioneer avh-P4000-dvd is there any way to bypass the e-brake on this thing other than the switch method
  • GLENHEN Jul 17, 2008
    When using a regular 12V 30 Amp 5 Pin Relay.
    Pin 87: ground
    pin 85: ground
    pin 86: amp turn on (from your deck)
    pin 30: e-brake wire (from your deck)
    pin 87a: not used
    Hope that helps.
The wire to the parking brake can be put on a switch.
the switch needs to turn on on right back off.
makes radion think PB came off
Posted on Aug 08, 2008
Let me know if you get an answer. i have the same problem
Posted on Jul 17, 2008
Bypass video on Pioneer AVH-X6500DVD
None of the above methods will work on a newer Pioneer. You can't just ground the wire, it won't work. The wire has to see nothing on it until the radio is already on and then needs to see ground. You can do it with a switch or a relay, but just grounded it does not work.
Dec 27, 2013 | Car Audio & Video
Need code to bypass e brake pioneer p1400 dvd
There is no code for bypassing the e brake.
Apr 10, 2012 | Pioneer Car Audio & Video
My avh-p4000 dvd is not displaying video when i insert dvd's I only recieve audio is there a switch that I need to set to get both audio and video
there is a light green wire that needs to go to the parking brake. video will not work unless the parking brake is on. this is for safety reasons and it is illegal for the driver to view videos while driving.
Jan 18, 2011 | Pioneer Car Audio & Video
Wat wire do i hook up to b able to view my movies on my pioneer avh p6500dvd
the green wire is the e brake cable if you ground this wire you can bypass the need for the e brake keep in mind that because of the type of deck you have you will need to install a switch and you will have to switch ths on and off everytime you turn into or awayfrom acc
Aug 24, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Blurry lines when playing videos from iphone/ipod pioneer p4000
sorry i have attemptede this 3 times.
Facebook send login info to the last registered email address. You should ask for a reset option
Jun 19, 2009 | Pioneer AVH-P4000DVD Monitor
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Watch a dvd while driving pioneer AVH-P4000 DVD
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Mar 03, 2009 | Pioneer AVH-P4000DVD Monitor
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
Mar 03, 2009 | Pioneer AVIC-D3 Car DVD Player
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Pioneer AVIC-D3 Car DVD Player Logo
440 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
