Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire frontl load washer and dryer manuel
Ihave no paper work on my washer abd dryer . I got them from a friend that had to sell them fast fore she had to move to a new town tor her job . SHE couldnt find the manuel and I dont know how to use this items so please help me understand the format of this fiigidiare affinity front load washer model no. LTF6000ESO 1/o6 Same for dryer model no. LEO6000ESO Thank you PLEASE HELP ME i do not what to mess them up or do somthing off the wall to them.
  • 876 Answers
The best thing for you to do is go to this link;
http://www.frigidaire.com/support/support.asp
and download new manuals and print them out. You will need them in the future. You will need both your model names and model #s when you get to this site to download.
Posted on Aug 02, 2008
Code E68
Posted on Sep 24, 2011
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Replaced the element on dryer and still wont heat but will spin and washer had quit working when old element went out
Good Afternoon Friend,
I understand the washer and dryer of your Frigidaire laundry center, model# FEX831CS, are both giving you troubles. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FEX831CS Top Load Stacked...
Turn off buzzer on frigidaire dryer LGR331SO
I understand that you want to turn the buzzer off of your Frigidaire dryer, model# LGR331SO. With your model dryer, you are not able to turn the buzzer off. I hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
WHY DOES MY WASHER/DRYER COMBO NOT TURN ON?
Hello Friend, thank you for your post!
Based on the symptoms you are describing, it sounds like your Frigidaire laundry center is experiencing an issue with the power supply. In this regard, I would suggest contacting an authorized service technician that will be able to assist you in the diagnosis of your appliance. Best regards! - Z
May 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
Oil inside tub after spin cycle coming from gear shaft
IHAVE THE SAME PROBLEM IN MY FRIGIDAire washer dryer stach top loaded machine, the oil and smell of oil comes after finishing spin , do you have a solution because I called the company dealer in my country and they want 400 dollars to fix it, I think they are steling coz the machine is working and spinning but only little oil with smell come at the end of the washing.
any help
thanks
May 07, 2011 | Frigidaire FWS833A Top Load Washer
Mildew smell on clothes
I have the same machines. Try using an old towel and detergent solution( use rubber gloves) and thouroughly clean the door seal. It can be just full of old lint, dirt, etc. in the grooves. Also try some oxyclean in your next load. That will help get rid of the odor also. These washers stay warm quite a long time and clothing will mildew fast in warm weather, but you probably already know that.
Aug 01, 2008 | Frigidaire ATF6000ES Front Load Washer
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Frigidaire ATF6000ES Front Load Washer Logo
451 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
