Before starting to graph Y= function, you should Turn STATPLOTS off.
Press [2nd][STATPLOTS] [4:PlotsOff]. command echoes ob screen as
PlotsOff . Press [ENTER] to execute it. Calc answers Done.
Press [MODE]
See if
Func, (4th line) is already highlighted.
If it is press Y= to start entering the functions.
If it is not highlighted, scroll down to 4th line, then use arrow to highlight Func an press ENTER.
Then
press Y= and enter the function. You see that as you enter the function
the equal sign becomes highlighted white on dark. Finish entering the
sunction and press ENTER. Cursor move to Y=2. Make sure that the equal
sign for Y1= is still highlighted. If not, move the cursor on it and
press [ENTER].
You can enter the variable X by pressing the
[X,T,theta,,n] button to the right of the green [ALPHA] key. Or,
alternatively, you press [ALPHA] [STO->] (X).
To graph Press
[GRAPH]. If you do not see anything on screen, it may be due to the
window dimensions. You can modify the window by pressing the [WINDOW]
button.
To test you configuration, I suggest you graph Y1=e^(x) and Y2= ln(x)
You
access the exponential e by [2ND] [LN] (e^x) and the natural log by
pressing [LN]. In each case you have to enter the right parenthesis.
This what you should get.
If
you are not familiar with these function, just enter Y1=X and you will
see a staright line passing through the origin (0, 0), just like the
one on the following screen capture.
Hope it helps.
