Question about Toshiba 34HF83 34" TV
Picture Problem -- TV Does not Turn On
I have a Toshiba 34HF83. It is about 3-4 years old and all of a sudden it stopped working. It does not turn on at all. Are there any parts that need to be routinely replaced every 3-4 years in this type of TV...i.e., the picture tube? Does anyone know how to order a replacement if that is so?
  • Toshiba Master
  • 5,568 Answers
I don't think the picture tube (CRT) failed.
If you have no sign of life at all such as a lit LED or similar, the unit either has a blown fuse (could be inside) or the power supply has failed or at least is starting up as it should.
But before getting carried away, plug a lamp or other device into the same outlet to be certain that the set is getting AC.
Then, check your user guide to see if they specify or list any fuse in the specification section.
If you find mention of it and replace it only to see it fail again, then there was a reason for the failure of the first fuse too, meaning it will need service.
Posted on Jul 13, 2008
Sound but no picture, tv turns off and on
It sounds Lamp is dead in your TV, how old is this TV and did you replaced its lamp recently?
Click Part Store to see required lamp image and price info.
Nov 02, 2009 | Toshiba 46HM95 46" HDTV
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
No picture on my tv
get a different tv but sel it first
Jan 11, 2009 | Televison & Video
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 36zp38b picture problems
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Mar 11, 2007 | Toshiba 36AF61 36" TV
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Nov 17, 2006 | Akai LCT2060 Television
Toshiba 34HF83 34" TV Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
