Question about Panasonic PT-LB50U Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
    Sniper:
  • 59 Answers
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Posted on Jan 21, 2011
2 Suggested Answers
SOURCE:
vortash
  • 431 Answers
SOURCE: Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
Posted on May 10, 2009
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
All of a sudden my left turn signal light came on and didn't flash on it's own in my '95 Volvo 960 and my hazard lights don't flash now or either turn signal flash but my left turn signal is a solid green...
SOUNDS LIKE YOU EITHER HAVE A BAD T-SIGNAL FLASHER,& OR SWITCH, OR A BAD HAZZARD SWITCH,& OR FLASHER,YOU MAY WANT TO CHECK ALL OF YOUR T-SIGNAL BULBS ALSO, JUST TO SEE IF YOU MAY HAVE A BAD BULBS, IT ALSO COULD BE A BAD GROUND ON ONE OF THE T-SIGNAL BULB SOCKETS.
Dec 05, 2009 | 1995 Volvo 960
Lots of details: LP120 stays on for a minute, then powers off
either the colorwheel motor is not getting up to speed to sync with the dmd chip, the wheel sensor is going, or the power supply needs replacing. you can try to replace them yourself or send it to an infocus authorized service center. try www.avsolutionsny.com . they're pretty good.
Sep 29, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
May 10, 2009 | Optoma HD72 Multimedia Projector
Strobing and sunburst effect on my plasma vizio p4
no bulbs in a plasma..
sounds like a video problem or centering problem ...see if can change the resolution or put it on auto and reset all to default through the menu.
Mar 17, 2008 | Televison & Video
Sony HS10 error lights
you could try a new lamp, some lamps fire, but do not stay on
Nov 09, 2007 | Sony VPL HS10 Multimedia Projector
Panasonic PT-LB50U Multimedia Projector Logo
14,765 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
