Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Propane coversion of kenmore 790 gas range
We can not get the oven to work properly. Bake flame is too high and shuts off automatically after a few seconds and the broil flame is too high.
Help.
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Posted on Jul 13, 2008
FLAMES TO HIGH IN OVEN G E GAS RANGE
Are you on propane (LPG) or natural gas? If on propane, then the oven has not been converted to propane properly.
Sep 10, 2014 | Kitchen Ranges
Broiler flame becomes weak
check lower broiler for clogs - spider webs etc
Jul 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My Kenmore propane oven is taking long then time needed to bake something
A very common problem when gas(both propane and natural) oven takes longer to heat properly is going to be a weak igniter . Since its weak its not fully opening the gas valve and not enough gas is flowing to produce the proper flame size/heat. By replacing the oven igniter it will heat as its supposed to .
GENE
Sep 24, 2011 | Kenmore Ovens
I have a kenmore gas stove 790-75711890. my oven ignitor was only glowing. so i thought not enough gas i removed pressure regulator and blow thur it then reassemble. still not liting. i bought new oven...
On the top of pressure regulater is a removalable piece that fits one way for nautral gas and the other way for propane i am wondering it was installed upside down afer ya reassambled it, accidenttly setting it to propane which defeintly will cause that
Aug 22, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven flame comes into the oven around the oven bake cover and all burners and broiler have a perfect flame. this is a brand new oven
Are you on natural gas or propane? If you are on propane did you have it converted form natural gas. Due to the difference in orface size you will be getting more gas flow then needed. If it was converted you need to contact the store and advise them it has a possible gas valve problem.
Jun 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
My oven does not light , only the propane comes through , and i have to shut it down , does not get up to temp
Your glowbar ignitor part number 5303935066 must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
The part is approximately $65 thru the Sears parts site.
Dec 28, 2009 | Kenmore Kitchen Ranges
We use propane gas. At first it had lots of flames and sooty smoke. We have adjusted the Regulator and the Oven Bake Burner as much as possible but it still has yellow flames like a blast furnce. What can...
The yellow flames is a sign of poor combustion which can release carbon monoxide. It sounds very much like the range was supplied with jets intended for natural gas which operates at lower delivery pressures.
You need to ensure that the range is usable in its current condition can be used with propane. Labels on the range (generally in back) should carry warnings about the proper gas and pressures.
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Gas ranges low pressue propane? 2 of them
The problem is with the tanks or the pressure regulator.. Call your propane provider and tell them what is going on. they should come out and replace the regulator and check the gas line for kinks or partial blockage.
Jul 11, 2009 | Kenmore 30169 Electric Single Oven
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
563 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
