Question about Maytag Performa PAV2200
Maytag Performa water level
My maytag performa water level is extra large no matter what i put the switch to.
  • Anonymous Mar 16, 2014
    The dishrack has been slowly disintegrating after a technician put a chemical in the dishwasher in order to remove calcium deposits. Where can I purchase another lower dishrack for our Maytag Performa?
  • 148 Answers
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Jul 13, 2008
  • derek martin Jul 13, 2008
    could you please give me a rating,I thank you
My Maytag performa series LAT2500AAE fills to the medium level no matter which setting I use. It does NOT overflow.
If your infinite water level switch has a reset, perform this before changing the water level setting prior to your next load, this is usually done by rotating the knob to the reset zone, then back to your desired water level setting. If your problem still exists, you will most likely need the water level switch replaced Part# 22001776. Pleazer Appliance...
Apr 16, 2014 | Maytag Washing Machines
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
My Maytag Performa won't stop filling up.
Your problem could be one of the following:
* water valve
* water level/pressure switch
Contact an appliance service company.
Feb 25, 2010 | Maytag Performa PAV2200
I have a maytag performa top loading washer, model # PAV3240AWW, that overflows. It doesn't happen every time and it doesn't matter what size the load is or what cycle I am using.
You have sand and sediment in the sump base of tub. All you di is remove the rubber hose on the water level switch and blow out the tube with your mouth. You will feel it when the **** is out of there. Then reconnect that hose tightly to the switch and pump out any remaining water in the tub. here are some repair photos
Oct 08, 2009 | Maytag Performa PAV3200
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Dec 19, 2008 | Maytag Performa PAV2200
Maytag Performa...It fills up and will not spin.
There are to devices that can cause this. The lid switch and the water level control valve.
Jan 09, 2008 | Maytag Performa PAV3200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
414 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
