Question about Polaroid FLM-2601 Television
Replace Capasitors Hello, Thanks for the advice, ive finally got around to looking at this TV, lve taken the back of the unit, there are three distinct 'boxes' are the dud capasitors the two large blue units near the top left. Sorry for the layman terms,
  • dana2aiken May 11, 2010
    how do you know how to take it apart? I dont want to break the thing
  • Anonymous Mar 26, 2014
    capasitor voltage is needed to replace old capacitors
    Problem Solver:
  • 3 Answers
Just start removing all the visible screws , The power module with the bad capacitors is the unit in the center , Wasn't rocket science to find it either , Just follow where the power cord connection at the tv goes to which board
Posted on Sep 08, 2008
  • flafyrman37 Oct 15, 2008
    Yes those are the bad capacitors
Heard loud popping sound from tv what is problem and how much does it cost to fix
not many components pop the worst are capasitors in any case tv repairs are not as costly as people think get a free quote without more advice on the fault i could only quess its cost but it starts around $ 80 for a service / slight fault up to $ 300 for main component replacment
hope this helps
post me back with more detail if you like
Dec 28, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
TV green light turns on. YOu could hear the audio out of the receiver which is connected to DirecTV. But, no video.
Hi, Look for bulging capasitors on the DM module board located to the left from the back of Tv and replace them. Should fix the problem or call a local Tv Repair Shop. Thanks.
Sep 22, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Need vertical ic replaced and capasitors. do
Don, who says you need the vertical ic replaced? Although you are to the point as to where the problem is. I think the ic is ok. The ic is a 7 or maybe a 9 pin component. In some cases it could be 13 pins. If you are sure where the location is, it is mounted to a large heat sink. I am not real sure of mitsubishi location scheme . If you can find it, most of the time pins 3 and 4 will be shorted. Measure to be sure. I think it is good. Look real close at the pins. They may have rings around them..resolder these making sure not to use to much solder. They should make contacts between pins. Now examine the four or maybe 5 capacitors with corresponding numbers. replace them with exact values. Use High Temp 105 degree ones. If you decide to replace the vertical ic, removed the clip around it. It will be the LA78--- series, cross it with an NTE replacement. see your electronic store for parts.
Jul 07, 2009 | Mitsubishi Televison & Video
DEAD TV
Check your all capasitors of pwd supply any capasitor is lickege or short or not work poperly if you cann't find any problem replace your all capasitors of pwd supply and check your pwd supply's Transistor or Mosfet
or Check your Horizonetal Transistor or Mosfet may be it is damaged
Mar 09, 2009 | GE Televison & Video
Screen goes black
The video adapter board is what controls the monitor. If you are going to replace a board that would be the one.
Dec 27, 2008 | Proview PL926WBi 19" LCD Monitor
I have a Hisense TL2020
this is an easy fix if you can solder.there are three capasitors on the power board that need to be replaced. radio shack has them for about 2.00 ea . or you can contact me.
spokane washington
Mar 22, 2008 | Hisense TL1700 17 in. LCD Television
HD52w140 Wont turn on.
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Dec 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCT HDTV
Dec 27, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 2720ba 52 inch projection
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Dec 22, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Polaroid FLM-2601 Television Logo
115 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
