Question about GE Profile Harmony DPGT750EC Electric Dryer
Harmony not heating
I have the ge harmony i replace the belt and put it all back togather and put a load of clothes to dry it got hot and almost dried them and now no heat i took it back apart no wires burnt of lose everything looks fine is there something that goes bacd and is a populer part that goes bad?
my email address is
thanks for your time,
  • 868 Answers
If your getting at least 110 volts at the igniter and its not glowing red ,than replace the igniter.If you have zero volts there you have to check for a bad thermal fuse or a bad thermostat.
Posted on Aug 18, 2008
My GE profile harmony dryer blows cold air on any setting do I need to replace heating element?
Yup...heating element (usually there are two) is done. Likely the first one was done long ago and the second has finally died.
Dec 03, 2013 | GE Profile Harmony DPGT750EC Electric...
Dryer taking to long to dry
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My smells hot and is putting off a lot of heat in
Vent pipe came off, most likely. I had same problem last week.
Jun 04, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
81 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
