Question about Canon NP 6050 Copier
Code E020 on a NP 4050
I checked the toner hopper-worm gear and all works are fine ( I even connected the hopper motor to 12 volts and all is working perfectly in the hopper). I also took out the ATDC sensor and cleaned it-but he error code is still there- what's my next step?
    Problem Solver:
  • 4 Answers
Cogz has a good idea. Could also be you waster toner hopper is full. Usually stored inside the drum unit. If drum has been in the unit for a while without being emptying it could cause an error. you will have to remove the drum and empty out than reset code and try again. If you have enough toner in the unit the sensor will pick it up. The toner sensor for the fill hopper is against the rear wall and make a small squeek sound called a Piezo sensor. Detects toner by sound. Hope this helps
Posted on Jul 22, 2008
  • Canon Expert
  • 1,326 Answers
How about this, Take the developing unit out and take the ATDC sensor out and plug the hole up in the developing unit. Reinstall the developing unit and cheat the front door switch and plug the sensor back in and hold it in your hand and make a copy. Dose it vibrate? If it dose not the sensor is bad... If you really get tired of working on the problem and you don't go to the copier to often and they are not billable, try this.... Take the top cover of the dev. unit and spoon toner into the dev. unit till it is almost full and reinstall it and clear the error code in service mode and just remember to add toner in to it every so often.
Posted on Jul 13, 2008
Canon ir2535 e00020 repair
Dear in most cases if toner refilled (or the life of the hopper assy.)the worm gear of the hopper assy. worn out. so the sensor at developing assy.detect no toner flowing to the developer from the hopper assy. where as the hopper assy. sensor detects toner. check the sensor, If you have knowledge enough to dis-assembly the the hopper assy. check the worm gear connected to a small motor driving toner gear. clean the sensor( may toner got inside the windows of sensor, clean it). check the harness, check the DC_CON pcb. Note if no experience donot open hopper assy. take assistance of trained engineer. Thanks.
Feb 21, 2015 | Canon Office Equipment & Supplies
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
Error code coo72
Your Hopper motor is not working, 72 is coming from the Toner Hopper motor....check motor check gears and check developer life,,,,,,
Jun 16, 2012 | Minolta EP4000/5000 CS/PRO Copier
Paper jam and give code C0070 at the screen. Model Minolta 4000
Hi this is a standars problem you will need to take apart the back of the toner hopper where the toner goes in the drive motor or worm gears will be damaged and will need to be replaced or the motor some times you just need to clean around the sensor toner hopper sensor and it will fix the issue
Feb 25, 2011 | Minolta EP4000/5000 CS/PRO Copier
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Oct 11, 2010 | Canon CLC 1150 Color Copier
I have a problem with code E020 (canon 1120)
E020 - The toner is not adding correctly into the developing assembly.
1) If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) If the hopper is 1/2 full or less, the worm gear splits under normal use.
1) Advise customer to add toner only when the toner light is lit, right away, and replace toner motor, or 2) Just replace toner motor (FH7-1762-030).
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller. It has been noted that some DC controllers do not provide sufficient current to drive the hopper motor. Replace the DC controller COL97.08.25 M0000244.txt.
Apr 14, 2010 | Canon CLC 1120 Color Copier
Cannon np 4050
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Jun 03, 2008 | Canon NP 6050 Copier
Error code E 000025-0001
 hello i m ramy,first  replace the toner bottle, second check the hopper motor connection,
 hopper motor unit gears.
or test if there 24 vdc .to the motor
Mar 27, 2008 | Canon imageRUNNER 5570 Copier
Toner
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
CANON CLC1000
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Canon NP 6050 Copier Logo
118 people viewed this question
old marine
old marine
