Question about Mitsubishi VS-45609 TV
YELLOW SCREEN MY TV SCREEN BECOME YELLOW AND SOME DOUBLE PICTURE AT THE END OF SCREEN
  • LIOZNYANSK Jul 13, 2008
    SCREEN BECOME YELLOW AND BLUE WITH DOUBLE IMAGE AFTER FEW MINUTES OF TV WORK
  • 6,487 Answers
Check this link for the some tips about your concern http://www.popularmechanics.com/technology/upgrade/2826881.html
Hope that helps...........
Posted on Jul 13, 2008
    President:
  • 2,712 Answers
Yup, either an IC convergence problem or an issue with the optical block. However, I would'nt recommend opening it up unless you have had prior experience, as these are very sensitive devices. You can try a repair under warranty, or if not, just look at the left of this dialogue box for a "Repair Service" box, put in your zip, and that will throw up a number of centers near to you. Mention that you were referred by Fixya, and hopefully, you'll get a good discount; but do shop around..
  • Mitsubishi Master
  • 19,396 Answers
Check lamps. If lamps are ok, replace the color wheel.
  • Ginko
    Ginko Jul 15, 2008
    In some case troubles with CRT board can give same symptoms, from description it seems more of a lamp problem.
  • 2,071 Answers
  • Mitsubishi Master
  • 13,433 Answers
How old is the lamp? the lamp may be failing and or the optical block may be damaged.
My tv lost picture and show only green screen although sound works
Hi, what you have is called hte "default " screen, the audio connection is apperebtly fine since you have sound, so the question is why video stopped. More than likely the video connection came loose somewhere, iI suggest retracing the " video connection " from end to end. If you're using an hdmi cable that has both audio and video cables combined-so it would be the cable or the player or jack on the tv's side that was defectice. if using standard " RCA " cables, those are the colors yellow, for video and red & white for audio. If someone or something become tangled in rca cables this may sometimes stress a connection and give a green screen ( with yellow cable still connected it will feel slightly loose ) I hope this helps ,good luck Prodzilla
Apr 10, 2011 | Sharp Televison & Video
My tv not showing picture some plug came off.
The tv needs to be pulled out if it is in a cabinet or moved slightly forward (be careful it doesn't fall on its face) so that you can reinsert the cable that has become unplugged.
The picture cables are either yellow only or blue red and green. so look for a yellow cable that is dangling or a blue or red or green cable that has become undone. The colors coordinate so the hole that the undone cable goes into will be the same color as it. Also check the other end of the cables to make sure that all of them are still plugged in.
If you are using a different sort of connection it is still the same idea. The cables have a spot on the television as well as any connected device that compliments them. The male cable fits securely into the female receptacle hole.
Mar 24, 2011 | Televison & Video
Picture has red vertical lines, will become
The problem is most likely the panel itself where the ribbon cables are corroded. There is however the also possibility that the tcon connectros need A clean.
May 23, 2010 | Toshiba Regza 47ZV650 47 in. LCD TV
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Televison & Video
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
I have a double picture on my 6 year old Hitachi Projection tv.
Required info are available in service manual with details and schematics.
You can buy service manual from Manual Zone for your Hitachi 51F500 TV.
Thank you.
Dec 11, 2008 | Hitachi 51F500 51" Rear Projection...
Mitsubishi VS-45609 TV Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
