Question about Olympus DS-40 Digital Voice Recorder
Olympus AS-2300 I bought my system 3-4 months ago. The foot pedal has given no end of grief. It was working intermittently, but now, after talking to Mike and Jeremy on the help line, it is not working at all. Customer service says to send it away to be repaired, that's the kind of service they are offering on this new product. I'm not happy about that. If I had time to fiddle with it, and then send it away, I wouldn't have bought it in the first place. My other one worked for ten years or more. Maybe this company just doesn't stand behind its products. I upgraded my Olympus 4000 to the 5000 model handheld digital dictating machine; and as recommended upgraded the old RS 25 pedal to new RS 27 pedal and also installed the new software from the included CD. Result is that the transcription program will not recognize the pedal even though Windows says the pedal device is working. Tried two different pedals on 2 different computers (running Windows 2000 and Windows XP) then tried the old RS 25 pedal again on both computers and no result. Tried several different USB ports with no result. Tried re-installing the software, no result. I'm assuming the new software should have included the correct drivers but can't find any info on the internet regarding driver updates. I may have to go back to the old software and old pedal.
    Problem Solver:
  • 9 Answers
If you installed the DSS Player Pro software that came with your DS-5000 voice recorder, then you installed the Dictation Module, not the Transcription Module. The footswitch will not work with the Dictation Module.
Check your program to make sure you have the Transcription Module. Release 5, with the latest upgrades to 5.0.4, will work with both the RS-25 and RS-27 footswitches.
Posted on Dec 30, 2008
    Problem Solver:
  • 7 Answers
The new DS-5000 SW has still got some quirks. The RS-25 is no longer available and I too have had issues with the 27. If your PC has a serial port try the serial plug, I know it is a step backwards but it has worked for me several times. Hope this helps. For now I steer clear of the DS-5000's.
Posted on Jul 16, 2008
My Olympus RS25 foot switch stopped working.
Yes, you can assume that after 6+ years, the pedals have gone bad and you need new ones.
Jan 08, 2016 | Olympus AS-2300 PC Transcription Kit
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
Auto Rewind
Try clicking on Tools, then set auto backspace.
Aug 09, 2012 | Olympus AS-2300 PC Transcription Kit
How to run AS-2300 software on Windows 7 Premium edition 64 Bit. Includes also foot padle.
The AS2300 foot pedal RS23 or RS25 are not compatible with 64 bit operating systems. You will need an RS27 pedal, available at http://www.dictationmall.com/147-035.html
Also the software is not supported on windows 7. You can get a free upgrade to the latest version, dss player standard, here. http://olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
If you have version 6, you need to upgrade to version 7 first. Once at version 7, you can then upgrade to player Standard.
Jun 21, 2011 | Olympus AS-2300 PC Transcription Kit
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
Feb 09, 2009 | Olympus AS-2300 PC Transcription Kit
DS-2300 recorder and DSS player transcription system
try reinstalling the software. And as for the foot pedals, take a good look at them and see if anything's wrong. If you don't find anything then plug it in and out a couple of times and make sure it's snug. For the phone, i suggest you buy a telerecorder. There about 5.35 and you plug into the microphone jack of your recorder and make sure to press record before each conversation on the phone. So far, that's all i can muster up.
Oct 01, 2008 | Olympus DS-2300 Digital Voice Recorder
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Olympus DS-40 Digital Voice Recorder Logo
641 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
