A/c blows hotair - Heating & Cooling
    Champion:
  • 254 Answers
Ok not to sound harsh here but please repost your question with the type of A/C unit. And model and s/n numbers. Most experts will not attempt to engage in a vague question. Once you repost will as much info as you can get on your unit you will get a much better response.
Posted on Jul 13, 2008
Mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Jan 05, 2017 | Mitsubishi Heating & Cooling
It is 9 degrees outside and my duo therm furnace is blowing cold air
I hope you have fixed it by now. Probably was the limit switch? don-ohio
Dec 18, 2016 | Heating & Cooling
Are daiken is blowing out warm heat an it's on cold an will not open by remote
call the ac technician as there is a problem in the board for the controls.
Jan 28, 2015 | Heating & Cooling
Johnson Starley boiler main board fuse blowing
Chances are the fuse on the circuit board is for control circuit protection. Take note of the location of all the thermostat connections on the circuit board and remove them. Do this with the power OFF. Replace the fuse and re establish power. If the fuse did not blow, the problem is in the wiring to or from the thermostat. It could even have the insulation rubbed through and making contact with the side of the boiler or a mouse could have chewed through the insulation causing a short to a metal object.
Once the issue with the thermostat wiring is resolved, reinstall the low voltage connections and you should be good to go.
Jan 08, 2015 | Heating & Cooling
My termost set to a/c, the fan auto, blow very well, but when I switch to heat and the fan auto, doesn't work, but if I put fan on work why?
the thermostat says to call for heat buildup in the work if its not cold enough the thermostat won't call for heat and I won't go on but when it gets cold and the thermostat set to the temperature you want or hire someone that doesn't cycle
Oct 12, 2014 | Heating & Cooling
Heat will not blow hot air model #310aavo48090oabjd serial #0205a42429
give name make of unit and set up of system oil/gas ect...
Oct 28, 2012 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
