My computer is giving the message ntldr is missing. I don't have a recovery disc to fix the problem. What can i do?
    Novelist:
    Scholar:
  • 96 Answers
First, check to see if you have a floppy disk in your floppy drive. if there is a nonbootable disk there, your system will give you this message.
It will also do this if the cables in your machine are loose (Some folks put their computer by their feet and can bump it loose on occassion) and the hard drive you normally boot to is not being recognised by the computer. Open it up and make sure all cables are connected to your hard drive and that they are all snug. Then try to boot up again.
To reinstall the Operating system, or recover one whose ntldr file is actually corrupt, you can use any Operating system disk of the same version as the one you have installed. Try borrowing one from a friend and run the Install during boot. be sure to look for the repair option that comes up fairly soon in the install process. A repair will replace the corrupted files and restore your system to good working order. If you find you are having trouble getting through this process, support.microsoft.com will have a walk-through for your to use. simply search for your operating system and use the words system restore, or OS repair
Posted on Jul 13, 2008
Ntldr missing
If you press F11 as you power up, it should find the restore partition.
I would place an OS disc of the same type installed on your laptop and run repair system.
Jan 28, 2014 | HP Hewlett Packard Compaq 6710b Notebook...
After system recovery using recovery discs of "PowerSpec" error message "NTLDR is compressed PressCtrl Alt Del to restart" appears .How to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Computers & Internet
Error message "NTLDR is compressed" how to fix it
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
My NTLDR is missing,what can I do to recover it.I don't have a recovery cd.
without the recovery disc you cannot fix the problem
you need to have the recovery disc as we need to copy the NTLDR file from the disc
Jan 09, 2011 | IBM NetVista PC Desktop
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
Ntldr missing
Thats the boot loader, youll have to do a system recovery using a disc that came with the computer. if you dont have a disc then u may be able to download a iso disk image from the gateway site.
Jan 20, 2010 | Gateway GT5220 PC Desktop
NTLDR is missing
problem:nt device loader error message
Solution: Reinstall windows
Aug 02, 2009 | Compaq Evo D500 PC Desktop
Acer travelmate 240 notebook - NTLDR missing message
if you had original xp cd, boot from cd then repair you system, otherwise use your recovery cd to give your friend a clear system.
Feb 17, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
