Question about Gateway MX8711 Notebook
Gateway MX8711 PC Notebook
How do i go about taking out the hard drive? my note book shut down and all i get is a black screen when i try the format cd's they will not fix the problem and it comes up with bad drive . i thank you for any help
thanks
darkness
  • 120 Answers
Check the following image for view of the bay (when upside down, the HDD is on the bottom left corner, just pull the screws, pull the cover and replace - powered off, of course):
http://images.tigerdirect.com/Skuimages/gallery/large/G153-MX8711-t.JPG
Posted on Dec 05, 2008
Gateway MX8711 Shuts off while running
I suggest you take your laptop back to the repair shop and tell them you still have the same problem. There should be a warranty covering the repair for a period.
May 20, 2012 | Gateway MX8711 Notebook
Computer will power up but not boot. Screen remains black. Battery charges.
If the screen's backlight doesn't come on at all, that's a new screen. You can find more from Gateway's support website. If the screen lights up but stays completely black, that's a motherboard issue, same fix. If the Gateway logo comes up but never goes into windows, that's most likely a hard drive issue, same fix. If you see an error message from Windows, that's a Windows issue. You could use the recovery DVDs that came with the system to fix that. Just put them in and turn the computer on. Press F8 repeatedly until you see an option to boot to DVD. Then follow the instructions.
Please rank if this was helpful.
Mar 05, 2011 | Gateway MX8711 Notebook
Y Gateway mx8711 does not write cdr or dvd's it reads them fine but does not write.
Is the WARRANTY on the computer still valid?
Either way, take your computer to a repair shop, and get the "broken" optical drive replaced.
Nov 05, 2010 | Gateway MX8711 Notebook
My gateway mx8711 notebook shut down when I plugged in the power cord. The battery was charged but now it will not turn on with or without the power cord. Is there a fuse in the unit and how do I get to...
Seems like the Main power board is short circuit.And the cause was not the fuse, it's the unit, and maybe the power transistor, my suggestion is, take it to the expert, Service Center maybe or else to solve the problems.
hope it help you.
Feb 22, 2010 | Gateway MX8711 Notebook
I have been trying to reinstall vista on my mx8711 but before install completes the screen blocks up and freezes and will not finalize installation,try to run fix says bad drivers how do i procede
you may need to re-format hard disk before installing the software as windows will try re-using the existing installation instead of re-placing it. start from the windows cd, then select to go to dos prompt.
type
format c:
then hit enter. this should erase existing data then procede with the normal instalation process
Dec 21, 2009 | Gateway MX8711 Notebook
Gateway notebook model MX8711 is freezing up - i get SMART msg that hard drive is bad and needs to be replaced asap - what hard is installed in this model?
Your laptop comes with a 100 gb SATA interface HDD running 5400 rpm. Any SATA interface hard drive will do. Pay a little more and get the speed up to 7200 rpm and you can use any capacity you can afford.
Oct 31, 2009 | Gateway MX8711 Notebook
No power
Sounds like a motherboard issue, BUT first try fixing it with a few basics like:
reseating / swapping the memory
removing the hard drive and then powering up the machine.
Try those two first and then report back.
Jun 13, 2009 | Gateway MX8711 Notebook
My Gateway MX8711 Notebook PC won't boot up. It will come on and show the Gateway logo and then go to start windows normally? but won't boot up. Goes to blank screen and then nothing..........HELP!!!!!!!
I had bought my Gateway laptop with the extended warranty at Circuit City and was worried that the warranty wouldn't be honored due to them filing for bankruptcy but I was pleasantly surprised. I was able to locate the company (Assurant) who is handling their warranties and they helped me over the phone. They had me re-install my operating system. He wasn't sure why it needed to be re-installed and suggested maybe a corrupt file, etc. Anyhow, I ended up losing all of my files but am just glad to have it fixed.
Jun 10, 2009 | Gateway MX8711 Notebook
Black screen will not boot at all
boot it, as it starts, keep tapping the F8 key,
should take you to, system startup utility,
take the top option
" last known good"
let it do it's thing
Reboot.
hope this helps
Regards
Richard.
Apr 20, 2009 | Gateway MT3422 RTL Notebook
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Gateway MX8711 Notebook Logo
140 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
