Question about HP Pavilion dv1000 Notebook
Laptop won't charge and fried jack and power adapter
My power adapter was fried on the end and it is loose when put into the power jack on the computer. I could get the computer to power on and charge if I was able to get the power jack placed a certain way in the jack. It ended up burning the power adapter more and it can no longer be used. I tried using a brand new adapter in the jack and it fried that as well. I'm not sure if the mother board is fried since it would turn on before or if it is just something with the jack. Any help will be appreciated.
  • Michael Hope Jul 25, 2008
    On my laptop the jack was busted off inside, if held just right would power up then after awhile it no longer would opened case and both legs had come lose rom motherboard, laptop is in a sack until i can get sombody to soder on a new jack.....and put it all bac together.
Go to www.pcrepairhelp.net
have not used them, but plan to send them a dv1000 with similar issues next week.
good luck.
Posted on Jul 25, 2008
Will not charge
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure your toshiba power cord is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Dec 12, 2012 | Toshiba Computers & Internet
Hp pavilion dv6 2117ax will not power up
Since you already got a new charger, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Replacement HP Pavilion DV6 AC Adapter 65Watt 18.5V 3.5A Option
Oct 28, 2012 | Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
I have a toshiba A215 and it will not charge. When I plug in the adapter, it says charging for a few minutes then it says plugged in but not charging....what could be the issue?
First thing I would do is check the outgoing voltage from the adapter. If it is going bad the faulty regulator could end up frying your motherboard. Laptops are very finicky about their power and it does not take much to screw them up permanently. Think simple first as in power adapter, then DC jack problem, then motherboard power circuit.
Sep 11, 2009 | Computers & Internet
Motherboard or DC Jack Problem???
i agree with your logic and think its a good idea to get the jack soldered to the the motherboard before anything else is replaced and would hardly cost anything too
Jul 26, 2009 | Computers & Internet
Charging problem
My shop charges $190 to resolder a new inside connection (if possible. need to see inside)
Replacing a motherboard is the price of mobo + 2 hr labor ($95/hr) = $440
I would test and make sure there's not a short in your power cable. Use a voltmeter and hold + inside and - outside and move the cable all around and see if it drops in and out. Other than that...it needs to see a shop.
James Mac
Aug 31, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion dv1000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
