GE A/C fan motor
I have a problem that you had suggested to some one else below. But want to know what I need to check my capacitor as the fan spins freely and is in fine shape, but if I start it manually (stick a screwdriver in to start spinning it) it stops spinning in about 30 minutes. It wont even hum at that point, it seems like an overheat switch as well? Any help is appreciated? You can email me at joe@joec.com (I am not sure how to check this). Thanks
Joe
    Scholar:
  • 104 Answers
A weak run capacitor will cause the motor to overheat and trip the thermal overload. You will either need a capacitor testet or a multimeter capable of testing a capacitor (read in microfarads (MFD or uF)). Sometimes if you are lucky you can get the local a/c shop to test it for you at the parts counter since they will be able to sell you a new one. MAKE SURE POWER IS OFF BEFORE YOU STICK YOUR FINGERS IN ANYTHING. The capacitors hold the peak voltage not the RMS voltage so there can be 370+ volts on an energized cap. Sorry, I am not set up to do this over email outside of FixYa but you should have received an email with a link to this response. Please take the time to rate my solution FixYa as I take alot of time to ensure the accuracy and detail of my solutions. If you have any further questions, you can post comments to this question and I will be automatically notified.
Thanks,
Chillmaster
Posted on Jul 14, 2008
I have a GE Minisplit model AE1C12DBH1 and the fan motor does not work, I would like to know where I can get it or a replacement part?
check for tight connection of motor in pcb and in strip, check for capacitor , if everything found ok then it means motor get blown off , replace it
Oct 12, 2013 | GE Quiet-Aire Ductless Mini Split System...
GE Spacesaver JVM140J 001, intermittent Vent Fan on Low
see the next steps for fix it, use the common sense.God bless you
First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start
Aug 03, 2012 | Microwave Ovens
GE Box Fan Motor ? No Capacitor?
mcdevito75 here, It could be bad brushes in the motor also, or a bad bearing or bearing cap in 1 of the motor ends.
Jul 27, 2010 | Dryers
Fan stopped running. no power to the fan (ie, no
You may find the parts that you need at the following web site...http://www.eceilingfans.com/
They have all of the capacitors there. All you need are the number of wires and the capacitor micro-farad ratings.
Dec 03, 2009 | Patton (PX400UC) 20IN Extreme...
Hi, This is Mike. My GE spacesaver xl1400 is shutting off as if it has lost AC power seconds after hitting the start button. The last couple of times it reset itself and now its dead. (power source is ok)....
-thermal cutout
-fan/fan motor
-transformer
-capacitor/diode
-circuit board, triac or magnetron
any of these could be the culprit
any of these can be tested
let me know if you need further instructions
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
Ge zoneline hvac
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Edgz
Jan 24, 2008 | GE Built-In Room Air Heat Cool Air...
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
