Question about Tech Solution TS-2550 Shredder
Makes noise but won't shred
I switch it to FWD and it makes noise, but it does nothing...won't shred..makes noise in reverse too...but since it won't shred, it makes no difference that it will switch to reverse.
  • SWALynn Feb 12, 2009
    Thanks so much for the idea but my impatience got the better of me & I threw it away months ago. Thanks again.
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Posted on Feb 11, 2009
Turns on, << works,won't shred when paper is inserted. doesn't seem to be jammed
Is it running in reverse? A lot of shredders have a switch for fwd/rev. Otherwise maybe the gears are stripped (plastic).
Dec 29, 2015 | Office Equipment & Supplies
Omnitech wont shred papers.
Sounds like its jammed? Have a really close look for staples, paperclips etc stuck in the drive gears or blades
May 19, 2015 | Office Equipment & Supplies
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
FWD IS REVERSE.
Hi, just reverse the wires on the motor, regards Phil.
Jun 10, 2012 | Boating
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Paper Shredder problem Royal JMD500 paper shredder makes a banging noise and paper only shreds about 1 inch in and then stops. You must put machine in reverse to take paper out.
Sounds like shreddder gears are not staying aligned or somethhing is caught in the cutters.
The shredder has a sensor to detect when somethine is insert. Hol the sensor swith down and check for paper clips or staples in the roller/shredding teath. Good Luck and use a match book on the switch to wedge it..
Sep 16, 2009 | Toastess International PV434995 Electric...
Will not shred, but makes clicking noise, will run in reverse
Possible that the actuator which feeds paper in has gotten affected. With the unit UNPLUGGED try looking to see if some paper has gotten wedged in there. If you can disassemble it you might be able to see the problem. Good Luck.
Aug 04, 2009 | Fellowes 3011001 Shredder
REALLY loud grinding noise
If it doesn't work at all, there is a reset button for the unit. After it is reset keep the cutters lubed.
Jul 16, 2017 | Royal CIA 12X Shredder
My car will not go in reverse but will go forward
typical FWD GM transmission issue, the transmisson will have to be rebuilt. You could try a fluid flush and filter change but there are only 2 discs pack for reverse. Which makes them fail very easily
Jul 06, 2008 | 1996 Chevrolet Monte Carlo
My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
Aug 30, 2007 | Quartet gbc 6120S Shredder
Tech Solution TS-2550 Shredder Logo
283 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
