Bose companion 2 series II headphone jack not working
We've had these Bose Companion 2 Series II speakers for about a year and the headphone jack has always worked fine until now. We just bought a set of Koss headphones tonight and plugged them into the headphone jack and there was nothing - the sound was still coming from the Bose speakers and nothing from the headphones - we took them back out and plugged into our laptop and they then worked so I don't know why they won't work with the Bose - any suggestions?
  • SKW Jul 13, 2008
    Never mind. Called Best Buy and it was still under warranty so they are going to replace FOC. Thanks anyway, and if you want to still post answers in case others need it, then feel free. ;-)
ginko
  • 19396 Answers
SOURCE: Bose companion II speakers
You mean this adapter: 3.5mm STEREO JACK M TO 2 RCA F ADAPTER
Posted on Aug 15, 2008
freetek
  • 5568 Answers
SOURCE: Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Posted on Apr 10, 2010
Testimonial: "Thanks for the insight! I noticed that when I unplug the power cord, the amplifier makes a loud crackling noise. I'll investigate."
walesarumi
  • 6993 Answers
SOURCE: Bose Companion 2 speaker. The
you can find an screws because there is no screws on the speaker box. The speaker box/cabinet is clipped together. You will be needing a flat screw driver to successfully open box.
Look at the side(s) of the speaker(s), you will see the where the box it joined together, use the flat screwdriver to put them together. Putting apart might not be that easy, so you will need to apply some force to take them apart.
You can use a gum or glue to put the speaker back together, because it might not completely join together like before.
Good luck.
Posted on Nov 01, 2010
SOURCE: Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Posted on Nov 18, 2010
bronk50
  • 27725 Answers
SOURCE: I recently bought some Bose
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Posted on Mar 22, 2011
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Bose Companion 2 speakers and Windows 7
Scan your computer with RadarSync so that it will detect which driver updates are needed. It will grab the drivers and update them.
David
Jun 26, 2013 | Bose Companion 2 Series II Multimedia...
Can i connect a tv to a bose series ii system
Yes you can, only thing is you may have to buy a 3.5mm phono jack to 2RCA converter.Because all standard TV audio out is RCA sockets unless you are planning on connecting the headphone out of the TV. This has an advantage, you can control the volume using the TV remote, but the disadvantage is if you turn up the TV volume very high the Bose may distort due to input overload .
Apr 18, 2011 | Bose Companion 2 Series II Multimedia...
I have a bose companion 3 series ii my base speaker has an broken audio input that i'm trying to fix can anyone help me Please!!!!
Yes you can fix it but need a soldering iron and tin and the part that will change. Get everything in radio shack or similar store. If you don't now how solderin go to this link: http://www.youtube.com/watch?v=Rm28jkKGMz4
Good luck
Dec 15, 2010 | Bose Companion 3 Series II Multimedia...
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
How do I connect my Bose Companion 2 speakers to my hp computer?
raio shack will sell you a "cheater cord" its a 1/8th inch jack to RCA connections. should be 5 bucks tops if you dont want 25 feet of wire.
Jun 10, 2010 | Bose Companion 2 Series II Multimedia...
Just purchased Bose Companion 2 speakers and I'm having difficulty connecting to my dell computer. Can you help?
What you need to do is connect your green audio jack from your speakers into the green audio connection at the back of your computer and you should have sorted it out :-)
Jan 02, 2010 | Bose Companion 2 Series II Multimedia...
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
Dec 26, 2008 | Bose Companion III Computer Speakers
522 people viewed this question
 Grubhead
Grubhead
