Question about Belkin (F5D72304F5D7000) Router
Low signal strength on Belkin F5D 8233-4v3 wireless N router
I bought a Belkin F5D8233-4v3 wireliess N router to replace my old Linksys wireless B router. I was especting a better reception from the N router. However, to my disappointment the signal strength of this N router is about same as the old rotuer (getting 1 to 2 bars and 11mbps). I place the new router at the same place as the old router (which is on the second floor) and my wireless laptop is on the 3rd floor. I had call the support staffs in Belkin and even updated the firmware but all this did not help. The reason why I bought this router is because I read many good report regarding this router. Anyone can help? Thanks.
  • tsuym Jul 13, 2008
    Please help.
    Sergeant:
  • 366 Answers
If you still get 11mb it's because in your network (check list of connected devices in router) you still have a 802-11B device.
chenge it to new N adapter
Posted on Jan 10, 2009
  • 148 Answers
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I want to extend the antenna on my d-link router. Reason: My computer shop is metal building, wireless signal is weak. As long as I don't short extension cable is this ok?
Instead of removing the antenna from the router you can buy a cheap working second hand router in market (better buy a second hand belkin router, because belkin provides free lifetime phone support also free lifetime hardware support for certain routers whose model numbers starts with F5D or F6D....Dont buy any belkin routers with model number that starts with F7D)
Now configure the second router as an ACCESS POINT (you can call 18002235546 to get help to change to an access point)
run a long ethernet cable from dlink router to the second router (belkin)... you can place the belkin router anywhere where the cable can reach...
The belkin router will broadcast the signal and you will get better signal strength...
Feb 03, 2011 | D-Link Computers & Internet
Hi I have a belkin F5D8233-4v3 router but the speed isn't what it should be. I have a 100/10 Mbit connection but when I have my computer connected through the router with a cable all the speed tests I try...
The speed of the wireless connection can be affected by -
1. The signal strength
2. Clashes with other wireless routers in your area broadcasting on the same channel
3. Electrical interference with the wireless signal
4. WEP & WPA Encryption of the wireless signal to prevent unauthorized access does slow the data transfer a bit.
That is why you are getting better performance using the LAN cable.
Jun 09, 2010 | Computers & Internet
Low signal strength
Having many users connected to a single WAP (wireless access point) will not affect the signal strength. It will however, affect the speeds each user is capable of.
Most Linksys routers have a homepage address of 192.168.1.1 - Enter this in your web browser.
From there you will be able to find wireless settings and enable either a password or a WEP key for security.
If you found this helpful please leave feedback.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Low signal strength on Belkin F5D 8233-4v3 wireless...
With speeds around 10 mb to the router over wireless you may want to consider checking if AUTO chanel is enabled or available on that model
If so then enable it.
Also consider moving the router if there are any other wireless devices nearby eg. cordless phone.
It may also be the the windows "zero wireless configuration" service is finding too many other wireless signals nearby that may be stronger than your own
If that is the case you may want to disable the service and set it to manual. Better still if you have a utility on the laptop (most have) then try set that to control the wireless setting instead of windows.
One of those last two items should help you maintain a better connection but only holds true if you have a reasonable connection to the router to start with.
You might also consider a cheaper wireless repeater to enable you to get better speeds
Jul 13, 2008 | Belkin Wireless-N Wireless Router with...
Belkin (F5D72304F5D7000) Router Logo
1,965 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
