Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
No Power to washing machine
I turned the washing machine on this morning and it started as per normal and started filing with water.
It stopped for no reason - NO power and no error messages.
I could smell a slight electrical burning smell when I lifted the lid. I turned off the power and pulled out the plug and left it for a good hour. still No power.
There is no issues with power from the point as dry works fine. I did run extension cord inside the house to make sure.
  • Anonymous Jul 14, 2008
    Started load, began as normal, heard two zap-kinda sounds, and the washer just dies, as it had no power to it....could smell a slight burning smell, something must have shorted?
  • Anonymous Aug 30, 2008
    I have not noticed a burning smell, but my washer stops during the load too. I have to unplug it and leave it that way for a while. When I plug it back in, the power comes back on and it indicates what stage it stopped at, and I have to push the start button twice (for some reason pushing it once pauses it). I have to do this three or four times during a load to get it finished. It is not spinning out the clothes as much either.
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
May 24, 2014 | Ariston Technologies Washing Machines
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
My Maytag Performa washing machine will not stop filling with water and start the next cycle
you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
Feb 09, 2013 | Washing Machines
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Excellence smart drive fills up with water and then doesn't wash
Hi just read your posting. Now when the machine stops does it sound a beeping sound and a series of lights light up? If it does starting from left to right I need to know what light have come on in the row of 8 lights.Is it the 1st and 5th or 3rd and 7th etc.Please reply 4 further help.
Jun 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Macchine won't fill with water normally
sounds like out of balance switch is faulty please reply if u need help to test.please turn power off b4 working on it.do not want any accidents
Mar 15, 2010 | Fisher and Paykel Washing Machines
Washing machine loud bang, now no water
you could have a broken or clogged bump,as far as the latch not opening it could be slightly off line
Nov 05, 2009 | Washing Machines
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
233 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
