Question about Linksys Wireless-G WRT54G Router
I recently changed my internet connection from DSL to Comcast broadband. I had the router connected previously without a problem, when I attempted to install it with the new service I got to step 8 on the set up wizard then it kept asking me for a password and I could not go any further. I finally gave up and reconnected my computer to the modem, then I lost my internet connection completely and I had to call Comcast to get it fixed. Now I am afraid to try it again. My Modem is Motorola SBV5220 and my computer is Compaq SR5110NX desktop with windows vista basic. Can you help?
    Novelist:
    Scholar:
  • 96 Answers
Three options here:
The first time you connect using most cable services, you may be required to register your computer to their service, which includes entering a password they give you. That may have interfered with your first attempt by not allowing your router to connect to the internet to obtain a public IP address form the cable modem.
If it's not the cable company's fault, the user manual that came with the router will also have the default user name and password listed there. Try using that in case it has been reset somehow.
If you still cannot get past the username/password prompt, then you can simply log into the router as before, and choosing to reset the router back to factory settings. Then you will be able to set it up again from the beginning.
Posted on Jul 13, 2008
Router communication with cable modem
If you change service providers, connection type and hardware, then all your previous connection settings will not work, and they'll have to all be reconfigured.
Have you been given a new modem/router (combo unit)?
Did you previously have a separate modem and a separate router?
Do you connect your xbox via WiFi?
Go back to basics now. If your computers connect fine, then connect the xbox using an ethernet cable and see if it works. Then try wireless.
Feb 27, 2010 | Belkin (F5D7230-4) Router (587009)
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Wireless router isn't getting internet connection
I am running DSL, but I am sure the method would be the same. The BNC connection (cable) should first enter the cable modem, then ethernet from the modem to the wireless router.
Jun 12, 2009 | Linksys Wireless-G Broadband Router
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
I have a linksys wireless-g broadband router. A couple of weeks ago I became unable to connect to the internet through this router. I am able to connect to the internet, however, using a direct connection...
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Dec 27, 2008 | Linksys Wireless-G Broadband Router
Linksys wireless g router will not connect to the internet
hello jillyg70
my name is tazman
have you tryed calling linksys they can help you . but you might want to try going to 192.168.1.1 first this will get you in to your router so you can set the settings on it. it might ask you for a password its admin try this before you contact linksys if you have trouble setting it up we have a premium chat i can help you
hope this works
Jul 06, 2008 | Linksys Wireless-G Broadband Router
Linksys Broadband Router Model WRT4G manual
Its wireless router.
When you have any wireless device like a laptop. you may connect wireless router and surf the net or mobile etc
Mar 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
178 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
