Question about Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier
Improper function when i first hooked my amp up, i noticed that it was delivering very little power to my subs.  when i looked at them in the trunk, I could see slight cone vibration but there was virtually no sound being reproduced.  this was the case even when all settings that affect sound were turned all the way up.  later on that day when i played with the balance controls on my deck, I noticed that when I put it all the way to left or right the corresponding subwoofer would hit hard, but then go back to nothing when i put the balance back to the middle.  So for now I have just 1 RCA input plugged in to my amp, and am satisfied with the sound, but I would like to get both of them on considering I paid for 2 and a 2 channel amp.  Any help would be appreciated.
  • 63 Answers
Try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Posted on Jul 13, 2008
My sound stopped working except the sub and amp.
If you have a little electronic know how... it can be a blown capacitor in the speaker. If you find it, solder a new one in and turn the volume down in the future. And look around for any signs of burnt insulation. Trunk amps are notorious for being insufficiently wired for power.
Apr 24, 2015 | 1998 Nissan Maxima
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
Amplifier and sub installation in a boat.
norally grounding them in the same place is ok but it could just theres not enough power from the amp too power two subs try hooking up one and see if that gives you the sound your looking for
Jul 09, 2009 | Car Audio & Video
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Subwoofers are working but aren't that loud.. help me!
not a bad set-up at all. i can help you i do need some more info though. what head unit do you have? what type of box is it just the normal rectangle box with or without divide sealed or is it ported? measure the size of the box and give me the dimensions please? how did you run the cables and how did you hook up between the deck and the amp? does the amp have built in crossover this could be problem just a little tuning? if it does make sure you selelct lpf mode and turn the hz knob all the way down ( counterclockwise) check the gain control should be another knob turn it clockwise all the way. you might need a little flat screwdriver to reach all these. is this amp bridgeable and if so are you running bridge mode ( 1 channel) if not look where you hook up the speaker and look and both channels and you will see a pos connect on 1 channel and neg connect on the other, put both neg wires on neg terminal and put both pos wires on pos terminal. in this set-up you will have full raw power. let me know about this and i will help you the most i can. good luck and happy booming.
Feb 28, 2009 | Rockford Fosgate Punch Stage P110 S4 Car...
No light on Alpine MRP-M1000
Ok. Have you check the Ground and the Power connection.
Jan 25, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Onkyo 805 sub hook up problem
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier Logo
90 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
