Washer just fills, nothing else.
Maytag A482 washer just fills and does nothing else no matter what the control is on. To get it to stop I have to pull out the control knob to the off position.
Hotpoint dryer does not get warm, what do I replace on that? No air blockage, filter is clean.
  • 3 Answers
Have you checked your lid switch?  Sometimes you can bend the metal arm to make better contact with the switch.
Posted on Jul 13, 2008
  • Phil Fleming Jul 13, 2008
    On the dryer electric or gas?
My maytag washer is shaking violently on the rinse cycle
I am currently having the same issue with my Maytag A482. Not sure if you have found a fix yet, or if you have replaced your washer. My washer runs fine until it nears the end of the cycle, when it begins to spin and shake violently, enough to loosen the leveling feet and rock back and forth. I pulled the front panel of the machine off (two screws near the base in the front, and two clips at the top) and ran a load through it. It ran fine until the end, when the machine started shaking violently. I did notice a few small pieces of roundish felt looking material sitting on the bottom, which after some research looks like it may be the damper pad. I found these online:
Damper pad 203956
Replacement Damper 203725 for MAYTAG Laundry Appliances A482
I am hoping this will resolve the issue, I will order them this afternoon and install them once they arrive. I really hate to replace such a good washer with a new high efficiency unit, which all seem to have terrible reviews after a few months/year of use.
Aug 25, 2014 | Maytag Washing Machines
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water won't shut off
Experienced a similar matter w/ ours that resulted in $3000 worth of floor damage in our house. The solution was an $85 service call for a tech to come out and reconnect a tube that detects when the machine has filled to the proper hight. Without this mechanism in place the washer thought it needed to continue filling (in our case it fille for 2 hours while we were gone). Sorry, never learned the proper name of this water pressure sensor.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
Washer Maytag Neptune
Most likely the motor control unit, the MCU controls the timer (loop circuit). Best way to check is to just pull the MCU out and visually inspect it for burned components, although it is not always visible. You may need to make some involved voltage readings to verify.
Sep 22, 2008 | Washing Machines
Maytag A482 Washer
either a water valve is stuck or most likely the pressure switch is bad check to make sure the hose is on the tub and back of the pressure switch and its clear if that's good replace the pressure switch its where you select the water fill on the drier first thing to check is the power dryers will run on 110 but not heat without 220 get a volt meter and check it where the cord attaches if that's good check the heating element
Jul 13, 2008 | Washing Machines
Maytag Neptune
the main control board could be bad, i dont want to tell you to replace it as it is expensive. call maytag and see if you can bring it somewhere to test.
Jul 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
