Question about Sony Playstation 3 (PS3) Console
I cannot get full color with my PS3 all the sudden
I've checked connections and everything is good. For some reason screen looks green with no red in it. I know it's not my TV, what's the deal? Any suggestions?
    Problem Solver:
  • 25 Answers
Try to put a ab convrter on it and see if it help / it is a device that chandges adio / video to cable wire conetion try that
Posted on Jul 13, 2008
When I try to play my ps3 it will freeze up and show these red and green lines on my tv
This is a GPU chip problem, it has a bad connection to the motherboard, that can cause YLOD, no picture, freezing, pixilation, no hard drive activity, no synchronization with the controller through the USB cable , colors get missed up , see lines and different forms of pixels on the screen then it freezes, all these symptoms indicate a bad connection between the GPU chip and the motherboard, there is only one real solution , Reballing the GPU chip , PS3 GPU chip is a very sensitive chip due to the fact that it has a built in memory chips so you need a very reputable place to do that procedure for your console , the photo story you see is an example of the reason and the solution and the link is for the place to fix it for you and give you a one year warranty on the repair.
56c8f7ed-37a5-4044-aae4-c4667c5361b8.jpg 0080ee9a-6834-4bf3-aa92-040ee20db882.jpg PlayStation3 GPU Reballing service
Apr 21, 2014 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on it turns green then it turns a yellowish-red color then blinks red what do i do?
Yes this sounds like the YLOD - caused when the GPU and the CPU overheat - you can send it in to fix but they will charge you for this. Or you can fix it yourself from home with a good repair guide.
CLICK HERE FOR A GOOD REPAIR GUIDE
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
Ok, I've seen all the 8million freakin 'hold button 5 seconds' explanations. All the other explanations, but I see NOTHING, nothing at all on my tv screen. My tv is a Jan'04 model, is this...
I understand your frustration - my PS3 went through about a two week phase where it only read disks about a quarter of the time. It sounds like you have gone through a lot of the standard troubleshooting stuff, so I'm just going to ramble some facts and ideas and hopefully something will be able to help you!
- If your television works, there is no reason it wouldn't be able to host the PS3 system. There is a chance that it will not support full 1080p high definition, but the PS3 is still incredible in standard definition.
- Have you used any AUX input devices on your television before to confirm that the red/white/yellow input jacks work? And have you checked any documentation on your television to see if there is some way to switch to AUX input?
- If you've pressed the button for 5 seconds, the PS3 should be using its default graphics mode, and will be in standard definition using the cables, so that shouldn't be the problem
- If the regular cable TV is playing, there is a good chance the TV needs you to ask it to switch to a new mode of input manually - is there a button on the controller labeled "input", "source", or "AUX"?
If none of these are any help, I would recommend going on eBay or heading to the nearest GameStop and buying a new set of connection cables - there is a chance that is the problem, and is a lot cheaper than tossing the PS3 entirely! Good luck, and I hope I was able to help!
May 06, 2011 | Sony Playstation 3 (PS3) Console
Red colored back ground
This is similar to the red light problem but the reason you get a screen is because the GPU has overheated.
You just need to stop the heat build up getting to the main chips and you will be able to play your games again.
To do this you have 2 choices:
Send it in and they will fix it for you although something to bear in mind that it will take 4 weeks and cost you $150 for the fix.
Or you can use a good PS3 Repair guide and fix it yourself.
A word of warning before attempting any home repair solution:
CLICK HERE TO CHECK OUT A FULL REVIEW OF ALL THE PS3 REPAIR GUIDES FIRST
I hope this helps.
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
The t/v screen suddenly turned green. the picture is clear but green/no color
Good day! the problem you have posted indicates that the 2 color cathode of your tv is not functioning, it's either that the driver transistor of the red and blue cathode is defective or the crt socket. or maybe the solder point in the crt board needs resoldering. check for some loose connections.
Sep 29, 2010 | Toshiba Televison & Video
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
69 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
