Question about KitchenAid KGRA806PSS Gas Kitchen Range
Set probe temp or remove probe
Screen displays "probe temperature or remove probe". We have never used the probe and do not remember receiving one either. We van not get rid of the message. HELP PLEASE!!
  • 1 more comment
  • ivan16 Nov 19, 2008
    probe temp or remove probe problem continues to display. Why? Ive never used one. kitchenaid gas range kgra806pss00
  • Anonymous Dec 26, 2008
    I have the same problem.. Guessing that the reason may be water leakage to the electronic panel
  • Anonymous Jan 17, 2009
    I have the same problem, Kitchen Aid has a 5 year waranty on the eloctronics, They dropped off a new control panel and I installed it myself, Sears has the part in stock if you are put of waranty, my question is are there any more screws to remove the front cover and how do I get at them? There is usually a $68 trip charge to get the part covered under waranty. It was most likely caused by some liquid getting into the button controls. wiwizzy@wi.rr.com
My oven keeps telling me to input a temp probe and it keeps blinking and its getting on my nerves.
Posted on Sep 14, 2008
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Why does wine freeze?
Check for corrosion on the temp probe. The digital displays use thermistors to determine the temp so if the probe has dust on it it will change the resistance reading and tell the cooler that it is warmer than it is. All you can do is clean the probe, and if that doesn't solve the problem then the control or probe are faulty as they are usually one piece you will have to change it out. If you are mechanically inclined you can change out the temp control with an a19 abc24c remote bulb temp control from Johnson controls and that will last of the rest of your life.
Sep 05, 2014 | Danby DWC283BLS Wine Cooler
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
Hobart L30 show code P3 and tempreture rises high Very quickly before it finsh filling
P3 refers to one of the dishwasher's three temperature sensors: sump temperature, booster heater temperature, or rinse water temperature. The dishwashers control circuitry has determined one of them is open or shorted, or at least out of range.
Judging from the symptom you mentioned, that you see rapid temperature reading changes before it finishes filling, I'd say it's probably the sump probe (because that's the temperature displayed during the fill cycle), located under the large removeable screen inside the dishwasher.
To test or replace, remove the small access panel at the lower front of the dishwasher (2 screws).
After the dishwasher has reached a good normal operating temperature, unplug the sump probe connector (white plastic connector with two small black wires going to it and coming from the area mentioned above where the temp. probe is. Using a multimeter, test the resistance of the probe. If the water in the dishwasher is hot (150 deg. F or more), you should read somewhere in the area of 5,000 to 10,000 ohms. If your measurement varies significantly from this range, replace the probe- most likely you'll see a reading near zero ohms or a very high reading, possibly an open-circuit probe (infinite resistance i.e. "OL" indicated on most multimeters).
It's possible I'm wrong about which temp. probe P3 refers to. There is also a temp. probe on the booster heater and one on the rinse piping on the rear of the dishwasher. Test procedure is the same for all of them, although the probe on the rinse piping is not constantly subjected to hot water so testing at room temperature would result in higher resistance value (lower temperature means higher resistance for these temperature probes).
Nov 18, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Oven fails to reach correct operating temperature. Set at 400 = actual 300 temp. Temp probe is clean.
Clean and working correctly are 2 different things.
Unplug the range. Remove the temp sensor. Use a meter set for ohms and read 1050 to 1150 ohms at room temperature.
If it reads OK replace the electronic control. If it reads bad replace the temp sensor.
Jan 04, 2010 | GE Kitchen Ranges
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
1,070 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
