Question about Electronics - Others
Installing an external drive
I bought an external case for my internal hard drive. I've followed the instructions exactly, but my computer doesn't detect the drive when I plug it into my USB port. I know the USB ports work, because they work for my cam, cell phone, and any other USB hardware I use.
  • ariet76 Jul 15, 2008
    geekohler, thanks for the suggestions, but I've tried both already. The jumpers are set to master, and the drivers are installed. The problem is, that when I plug it into my USB port, it's not detected. I don't know what to do to get it working.
  • 304 Answers
Check the jumper setting on the back of the hard drive and make sure it is set to master. You may also have to install the driver for your external case, should have came with and install cd
Posted on Jul 15, 2008
Can it be connected to more than one computer?
Yap this is possible by sharing your External hdd from your physically connected Computer. Follow the instruction under the following.
Connect the external hard drive to the computer and turn it on. Go to "My Computer." Right-click the name of the external hard drive that you want to share and select "Properties." Click the "Sharing" tab and select "Advanced Sharing."
Mar 17, 2016 | Click Free Automatic Backup C6 1 TB USB...
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
My sabrent ec-ueis7 external hard drive enclosure will not allow me to initialize the drive. the drive is a 1tb western digital hard drive that was in a Western Digital My Book Essential case that broke....
If the drive has important data on it then the last thing you want to do is initialize it - that will wipe the data. Can you try installing the drive inside the machine on an active SATA port and run spinrite to see if the drive is salvageable?
Jun 30, 2017 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
Power turns on, but there is blank screen with small gray picture of the folder with ? on it
This is not good news. That blinking "?" icon means that the computer is unable to find a disk drive that contains what it needs to start up. It's a real problem, and if you are not an experienced computer person, consider getting professional help with it.
- The worst case is that your hard drive is seriously damaged - you're going to need a new hard drive and you've probably lost all your saved stuff
- Or, if you're lucky, some essential files are missing or damaged but the rest of the disk is OK.
If you want to try and solve this yourself, here's what to do:
If you have the disk that came with it when you bought the computer, put that in the disk drive slot and try again to start the computer. If the computer still won't start up, you definitely need professional help.
If it starts up using the DVD, the very first thing you should try to do is recover and save (back up) all your saved files. Do that before you try to fix the bad hard drive.
Look on the screen for the icon for your hard drive. If it's there, that's good news because you should be able to find all your valuable files and copy them to an external disk drive. If you don't already own an external hard drive, I recommend that you seriously consider buying one. After you've gotten this mess straightened out, I recommend that you continue to use your new external drive, with Apple's "Time Machine" software, so you always have your stuff backed up.
After you've backed up your files, go to the folder on your desktop for the CD that you booted from and try reinstalling MacOS. If the reinstall works, you'll be back in business. If it doesn't, you'll have to replace the hard drive.
Jun 13, 2011 | Apple MacBook Laptop Computer Mac...
Hi, Maxtor 90645D3 hardrive deletion manual jumpersettings.
Basic jumper settings for Maxtor ATA Hard Drives
Thank you for purchasing your new ATA hard drive from Other World Computing! Please
review these jumper settings prior to installing your new hard drive into your computer.
You may want to review more detailed information about the installation process, or
the location and configuration of your existing internal ATA drive before proceeding.
Your manual that came with your computer can be of assistance in both of these
determinations.
A few notes about installing an ATA hard drive into your existing system:
Your existing drive is normally configured one of two ways, Master (single drive), or
Cable Select. You will want to determine this before installing your new drive, the easiest
way is to remove the existing drive from your system and visually inspect it's hard drive
jumpers. Most hard drives have a schematic either silk screened onto the case of the
drive, or the schematic is on a label near the jumper pins. If you have difficulty locating
this information, visit the hard drive manufacturer's website.
If your existing hard drive is configured as "Master", then set your new hard drive
to "Slave". If your existing drive is set for "Cable Select", then set your new drive to
"Cable Select" also. You can change the existing jumper settings on the original drive
to suit your needs, but we recommend following these instructions first to verify proper
operation of the new hard drive.
Installing jumpers on the new drive is a simple process, follow the schematic to
configure your drive.
Please note the configuration of
the internal ATA cable already
installed in your existing system.
If your internal cable is configured
differently than pictured here,
you may want to replace it before
installing a new hard drive to
achieve maximum performance.
For further assistance, visit our tech center at http://eshop.macsales.com/Tech/index.cfm
Mar 10, 2011 | Computers & Internet
Hi i`ve just bought the wd elements 320gb yesterday. the problem is that i put the usb in and the light on the product is on but thats all. its not installing and i cant find it on my computer.
The obvious question first is the drive connected with the provided AC adapter?
Are you connecting it directly to a USB port or powered USB Hub? This is not important in external hard drives but it does on portable HD. But just in case keep this in mind.
Other thing is that you have to install the WD Smartware software.
If nothing works, try it on another computer.
If it works, must be a USB port problem.
God Bless You!
Feb 05, 2011 | Western Digital Elements powered by WD 320...
Myexternal hard drive wont boot and it says its unreadable or corrupted. maxtor 500gb tried a lot to resolve proble what exactly now i cant remember
You need to include info about your computer, and which format your external hard drive is: USB or Firewire. Are you using a Mac or PC?
"Boot" refers to the situation in which your hard drives sets up the operating system of your computer. I doubt this is the case. Do you mean that your host computer does not recognize the external drive?
If the latter is true, this can have many causes.
Also, did this drive work at some time? If so, with this computer, or a different one? The problem may be as simple as installing the proper driver, or at worst, the drive may be non-functional.
Most manufacturers of mass produced external drives, in the interests of being competitive, use drives that are not as durable as you would expect in a backup drive. Also, the interface in the case that houses the external drive often fails, so the drive itself may be OK. You can check this, but observe the following conditions:
1. You will void the warranty if you open the external drive case.
2, The warranty will replace the drive, but will not recover the data on that drive.
3. You can remove the external drive from the case and install it in your host computer to check it, if your computer is compatible with that drive. You need to know how to set the jumpers of that drive for your setup.
4. This can be a difficult and frustrating process. If the data on the drive is important enough, you have to decide if the cost to retrieve it is worth it to you.
Contact me if you need more info.
Oct 28, 2010 | Maxtor Hard Drive
Need Manual or Instructions for Seagate Portable Hard Drive
Your External Drive should be plug and play enable since it is a USB Drive.
Connect the appropriate cables to the External Drive and from the External Drive to the Computer while the computer is fully booted.
The driver for the Drive is loaded else you will be promted that the system have found a new device, if that is the case, put the CD-ROM that came drive and follow the instruction to complete the driver installation.
Open my computer icon on your desktop and you see the external drive.
Feb 01, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I don't know how to attach the usb cable to the external hard drive?
Connecting an external drive is much easier than installing an internal drive because you don't need to open the computer case. The drive attaches to a connector either at the front or the back of the computer case; power is supplied by a separate cable
Available connections. Your PC is likely to have one or more USB 2.0 connections so plug into this your attached harddrive usb wire
Jan 04, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Electronics - Others Logo
29 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
