Question about HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
The green light is blinking on the supply unit but it not coming on or booting up , i need to know if the supply unit is bad
  • 1,138 Answers
Close examination of your power supply may reveal if the psu is bad.
When the power supply is plug in ac socket the green indicator led inside the motherboard will lit steady green. See if by turning on the cpu you will see some sparks in the power supply connector attached to the motherboard. This is a clear indication of a bad or shorted psu.
You can also smell if there is a burning inside the psu.
See if the fan inside the psu is working if not then its a clear indication of a bad psu.
Using a multimeter if you have one measure the dc voltage coming from the supply connector. Insert the black probe to one of the black wires in the connector. And the red probe to the red wire in the connector. the reading should be +12VDC. Put the red probe to the red wire and it should read +5VDC. Any readings below this, means bad psu.
Measure also the output voltage when there is a load in the power supply. Connect a CD-ROM drive or hardisk and measure again the voltage. Dropping of voltage when put some loads is a clear indication of a bad power supply unit (psu).
I hope this will help you.
Thank you for using Fixya!
Posted on Feb 06, 2011
  • joecoolvette
    joecoolvette Feb 18, 2012
    1) ALL Black wires are Ground wires, coming from the Power Supply.
    2) RED wires are 5 Volts.
    3) YELLOW wires are 12 Volts.
    4) ORANGE wires are 3.3 Volts.
    The Red probe lead is the Positive lead. It touches the power wire.
    3.3 Volts, 5 Volts, or 12 Volts.
    The Black probe lead is the Negative lead. It touches a Ground wire.
    A - N - Y Black wire is a Ground wire.
    ALL are DC Voltage. Set the multimeter to DC Voltage.
    If just a symbol by the Function knob of the multimeter, the symbol is a dotted line over a solid line.
    If more than one scale is offered for DC Voltage, use the 0 - 50 Volt scale.
    What is bad are Electrolytic Capacitors. The weakest link in the Power Supply.
    The large one's where the AC power cord comes in, are Filters for the Input Stage.
    The smaller one's are also Filters, and they are in the Output Stage.
    Electrolytic Capacitors have an Electrolytic Paste inside. When the capacitor goes bad the paste develops a gas (Hydrogen Gas), and the gas expands inside the capacitor.
    Eventually the resulting pressure from the gas compromises seals of the capacitor, and allows Electrolytic Paste to slowly ooze out.
    So much paste loss, and the capacitor operates at a weakened state.
    Too much paste loss, and the capacitor fails.
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Sony VAIO VGC-RB42G - No Power; Blinking green light on power
Try a different known working power supply on that computer, the green light on the power supply should be constant and not blinking. The green light on the motherboard shouldn't be blinking either but if its not getting the right voltage from the motherboard then it will blink as well.
Get a different power supply and see what happens. At that point the power supply green light should be constant, if its not then your motherboard is faulty at that point, if yout the green light is blinking on your motherboard, if both are constant then reseat the memory and CPU and only have the power supply hooked up to the motherboard and not to anything else.
If you still can't get video then at that point you know the motherboard is definitely bad.
Aug 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
System doesn't boot up
Try to use a new power supply, the power supply can not reach the voltage that have some components of the power supply are faulty already you need to replace the power supply.
Aug 01, 2009 | Dell Dimension 4550 PC Desktop
Not booting, blinking light
4 blinks, 1 second apart is a power supply overload. Have the power supply replaced if you haven't added any additional hardware lately. But also make sure your hard drive isn't bad and pulling an overload of power. it's rare, but I have seem that happen on some western digital hard drives.
Jun 13, 2009 | Compaq Presario 5000 PC Desktop
Sony Tower green light blinking
Could be a bad power supply or a bad motherboard.
Mar 21, 2009 | Sony VAIO VGC-RB42G PC Desktop
Display gone, no longer functioning
Green light but no display- most likely main transformer is gone (60%), 35%- blown main fuse, 5%- bad display or power supply. You are lucky if unit is still under warranty. Solution- repair shop.
Dec 31, 2008 | Denon AVR-2807 Receiver
Power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Nov 26, 2007 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Logo
481 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
