Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Hoover self propelled upright
Your answers seem so very clear. My problem is that the self propeled feature only works in one direction. I assume that there is a cable that controls the direction. Can you tell me how to replace or repair? Thanks
Keith
ps I wish the drawing were larger in size
  • kjohnsonmi Jul 14, 2008
    Thank you very much. I see the cable and now will be able to fix the problem. I must tend to make the problem bigger as I was thinking the whole lower assembly would need to be dismantled.
    Anyway, thanks again for the excellent advice and the prompt reply.
    Keith
    Cadillac, Michigan
  • Anonymous Sep 13, 2008
    My windtunnel (hoover u6616-900)will not sef propel. drive belt in good codition and in place,
    President:
  • 1,673 Answers
You can adjust the cable, it is from the front, on the right side, it has a torz screw that you loosen, then you can slide the cable back and forth, just move it alittle back then tighten it down and try it. Here is a site that you can see a bigger picture: http://vacuumsuperstore.com/U6625part.html
Posted on Jul 13, 2008
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Self-propelled Broken?
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Aug 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
151 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
