Question about Maytag Neptune MAH5500B Front Load Washer
MAH8700AWW We were washing a load and the water is not draining into the bin from the detergent resevoir.. This is the first problem like this that we have had, and we took the resevoir out to see if there was something clogging it but no build up (we only use liquid detergent)... What can I do, my manuel only has suggestion if it is not draining while in the spin cycle.
  • Anonymous Jul 13, 2008
    The cycle begins ok but doesn't sound like its agitating. Just goes through the time on the computer setting does not spin out properly and ends with a LR code.
    I have unplugged to reset. I have tried the various cycle options. The rinse cycle doesnt take the fabric softner so evidently its not doing that either
  • mpina Jul 31, 2008
    Wahser appears to be working but has problems rinsing the clothes. Even adding smaller amounts of detergent still gives the suds message many times. Also, doesn't take the fabric softner so evidently its not doing that either. I tried taking it out to make sure it is not clogged. Still the softner is not taken by the machine during the rinse cycle.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Push a drinking straw through the outlet on the conditioner outlet and the detergent. I thought mine was clear till I did this and found a load of gunk came away. Keep it clear now by regular washing in soapy water.
Posted on Aug 03, 2008
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
MAH8700AWW washer door wont open
hi adriana it is possible there is still water in the drum if that is the case the door wont open untill you empty it,this can be done by draining the water through the filter drain located at the front of the machine ,i hope this helps .
Dec 29, 2011 | Whirlpool LHW0050PQ Front Load Washer
Maytag MAH8700AWW - detergent drawer full of water
try removing the drawer to see if one of your kids has put something in there
Dec 13, 2009 | Washing Machines
Clothes stink on top load model
Continually washing with cold water and liquid detergent can cause a buildup of undissolved detergent between the inner and outer tubs (unseen). This buildup of detergent feels like grease and will pick up dirt from each load and hold it on the grease surface. Over time...the dirt held in the greasy detergent can give off an odor.
This problem may be able to be cleared up by running many loads of hot water (to dissolve the detergent) with no clothes or detergent. Switching to powder detergent will also keep the liquid detergent gel from forming. If you like liquid I recommend using hot water for ALL your white loads. This should make every third or fourth load hot and help dissolve buildup from previous loads.
If you are not in the habit of using cold water and liquid detergent consider other sources of the odor. Some typical examples are sewer or septic backup through the drain and into the machine between the tubs where you can't see it. Also, the laundry is usually in the basement if you have one. The basement is the lowest part of the house drainage system and if you are developing a slow drain you may find some dirty water backing into the machine if it can't go down the drain quickly enough. Usually these drainage issues show up as a floor leak when you drain the washer in the spin cycles...but not always.
Good Luck.
Sep 17, 2009 | Kenmore Washing Machines
Water and detergent are in the bin after wash cycle
check to make sure water lines are not clogged and detergent tray is not caked up
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Bosch washer smell
Just clean the filter and make sure all the water drains from the pipes, That water can be a realy smelly story, i know.
Good luck...
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
