Question about Whirlpool LER4634J Electric Dryer
Whirlpool Dryer Problems
I have a Whirlpool Dryer (I'll have to get the model number if it's necessary). It stopped heating and then quit all together. I unplugged it and plugged it back in and it worked just fine. It heated and worked for about 1 day. Then it quit again and wouldn't do anything. I checked the power source and it is getting appropriate power. What else could be the problem? Thank you.
  • 89 Answers
Contact the manufacturer. some parts might need to be replaced already.
Posted on Aug 24, 2008
Whirlpool dryer stopped heating Model - wed5500sq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,.,.
Mar 21, 2011 | Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER MODEL LER4634PQO...IT WON'T STOP RUNNING WHEN IT GETS TO END OF CYCLE AND IT DOES NOT HEAT UP
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 10, 2011 | Whirlpool Dryers
My dryer will not heat up. model number LE9480XWW1 stock number LE9480W
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Whirlpool Dryers
The gas heat stopped today
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 06, 2010 | Whirlpool LGR8648L Gas Dryer
Dryer spins but does not dry brand is whirlpool model #LE7680XSW2 can you tell by model number what the capacity is. Thank you
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Whirlpool LER4634J Electric Dryer
No heat
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Jul 18, 2009 | Whirlpool Dryers
Dryer wont start
Okay...your dryer is one of the more easier dryers to access the heating circuits. All you have to do is unplug the dryer and remove the back panel. The heating circuits will be on the right hand side (as viewed from the rear). The heating element is inserted inside the heater box with the thermal cut-out (TCO) mounted on the top portion of the heat box. The hi-limit thermostat will be located adjacent to the heating element ceramic terminals. You mentioned a thermal fuse also. It is a small white plastic (sometimes gray) looking component mounted on the blower fan housing on the lower left hand side of the dryer (as viewed from the rear).
If the dryer does not run at all, the THERMAL FUSE is a good diagnosis on your part.
If the dryer runs, but does not heat, the THERMAL CUT-OUT, heating element or hi-limit thermostat are your likely problems.
The following link provides you with some necessary guidelines on how to troubleshoot if needed:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Most dryer problems are related to overheating caused by poor ventilation, or overloading. If you need a drawing of your dryer heat components you can reference searspartsdirect.com. Just type in the model number you provided (include the prefix "110", this identifies the manufacturer as Whirlpool). The number should be written as follows: 110.66801691. Look under the "Bulkhead" heading for an exploded view diagram of your dryer. The Thermal Fuse is listed as item 59 (part #3392519). I hope you find this information helpful. Let me know if you have any questions.
May 03, 2009 | Kenmore Dryers
Dryer was working fine then quit heating
go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Jan 13, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer Not Heating
ive got same problem and engineer told me to buy a thermostat kit cheap and easy to do yourself.loads of sites sell these but i cant find one that matches to my model number.you might have more luck.
Sep 08, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric
How old is the dryer? The heating element is probably no good.
It's possible to fix it yourself. Make sure it's unplugged before you start. You might want to check a parts store, or online to see what the heating element would cost. when this goes bad, the dryer will still spin, and the heat stops instantly. It's a little tricky taking the panels off, but there's not too much to a dryer. An electric motor that powers a belt to make it spin, the heating element, metal sides, top and bottom. Good Luck! Countrycurt0
Jul 25, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
