Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Wireless network adaptor
Don't know what my WEP is
You can get your WEP Key or WEP Encyption Key on your Wireless Router's Configuration Page.
Open your Web Browser like Internet Explorer or Firefox or Safari, type the IP Address of your Router on the Address Bar (e.g. 192.168.0.1) log in to your router and check the wireless settings and look for your network key.
If you dont know the IP Address of your router, try checking it on the command prompt.
Click Start, then click on run, on the run windows type in cmd for command, a black screen will pop up, in the blinking cursor type in ipconfig for Internet Protocol Configure it will show you the IP Address of your computer and the router's IP Address which is the Default Gateway
Hope this helps
Posted on Jul 15, 2008
Don't know my password
Are you looking for wireless network password or Linksys router password?
If you are trying to connect to the wireless network then it might be asking you for the wireless network key or the passphrase.
You can open the setup page of the router and check the wireless settings.
Read Wireless network key WEP WPA
Dec 12, 2011 | Linksys Wireless-G WRT54G Router
Ngb416n using wpa2 psk security. works ok to internet with LAN cable, but wireless in Windows 7 shows a red x next to the wireless. We used the wizard to setup and the name of the network matches what we...
Some wireless adaptors may encounter the compatibility problem with some routers when adaptor's driver is out dated. I have a Toshiba laptop that had the same problem. After I installed the latest driver, the problem resolved. You may need to contact manufacturer of the computer to get the updated driver. If you cannot get a driver updated, you can also try to lower the security to WEP.
Aug 17, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
I have an I4 phone. The only wifi I can connect to is Linksys. I have other networks available but don't know codes to join with. What to do?
Hi there!
It is possible that the Linksys wireless doesn't have any password/WEP key to connect that is why your phone can connect to it. You can't the other networks available if you don't have the password/WEP key. It has password enabled to prevent unauthorize connection to the wireless. I suggest you subscribe to your own wireless connection so you don't need to worry about connecting to any wireless network available.
May 08, 2011 | Apple Cell Phones
I have a 2 wire adaptor and comcast internet a motorola modem. i really need to know can these two work together and what would be the network key?
Yes they should be able to. You will need to contact comcast on how to obtain your network key. Have them instruct you on how to chage the security to WEP if it is not already there.
Mar 21, 2011 | 2wire 802.11g (66800007236) 802.11g/b...
I have a belkin wireless adaptor, but a D-Link router, how do i link them!?!?????
You need to know the wireless settings on the Dlink router first. To check the wireless settings, you need to use a wired computer to the router.
Then in the address bar of a web browser (Internet explorer or firefox), type 192.168.0.1.
By default, the user name is Admin and leave the password empty.
Go to Wireless Settings. Take note of the following:
1. Enable wireless should be checked.
2. Take note of the wireless network name. You may change this into a unique name so that you can easily determine your own wireless network.
3. Visibility status should be Visible.
4. Under Wireless security mode, it depends on you if you would like to enable it or not. If you would like to enable the security, just select WEP. Then enter the WEP Key 1. This is like a password for your wireless network, use letters from A-F and numbers from 0-9.
Then click Save Settings.
Once the belkin wireless adapter is installed properly on your computer, there are 2 ways to connect to your wireless network.
Either you use the Belkin WLAN monitor or the Wireless network connection (for Windows OS). When you view the available networks or Site survey, you will see the wireless network name on your router. It will prompt you for a network key if wireless security is enabled.
Make sure you enter the WEP key 1 in your router. This is case sensitive.
I hope this helps! Good luck!
Mar 22, 2010 | D-Link DIR-615 Wireless Router
Right, do not know what I am doing but here goes....connected desktop pc to wireless router, then tried to do the same with my Fujitsu Amilo laptop and can't, i've gone into adminstrator command prompt...
Make sure first that you know the wireless settings on your router. Take note of the SSID (wireless network name), wireless channel, wireless security settings (WEP/WPA, preshared key/passphrase/wep key/wireless network key).
For Win XP/Win Vista: On the system tray (lower right corner of the screen; near the clock), right click on the double-monitor icon that says Wireless network connection. Then select View available wireless networks.
You should detect the SSID or wireless network name. Highlight it, then if it asks for a network key, you need to type the wireless network key. Then click connect.
Hope this helps!
Oct 22, 2009 | Computers & Internet
Can't connect the artisan 800 to our wireless network
To add the printer to your wireless network, you need to know the name (SSID)
of your wireless network. If it has security enabled, you also need to know the
WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
■ Network name (SSID): _________________________________________
■ WEP key or passphrase: _________________________________________
Note:
If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
characters, it’s hexadecimal. The default WEP key is usually 1.
If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
The printer supports the following wireless security modes: WEP 64, WEP 128, and
WPA-PSK.
If you don’t know your wireless network name (SSID) or WEP key or passphrase,
contact the person who set up your wireless network before you begin.
Insert the printer software CD.
2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
When you see the User Account Control screen, click Continue.
Windows® XP: When you see the Software installation screen, continue with
step 3.
Mac OS® X: Double-click the icon.
3. Click Install.
1.Make sure that the printer is turned on.
2. When you see the FireWall Warning screen, click Next.
3.Make sure you connected the Ethernet cable
Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
Hi, I have a toshiba windows XP laptop which stopped connecting to wireless network(WEP) .But it connects to network through LAN with ethernet cable .Laptop wireless finds my network but does not connect(...
Check your security settings would be a good start. Have you checked to see if XP uses WEP to authenticate? (it should do this automatically but sometimes it doesn't)
Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
