Question about KitchenAid Washing Machines
How do I remove the top of a kitchenaid washing machine?
    Genius:
  • 1,028 Answers
You don't remove screw in rear each corner of console lift console up and back disconnect lid switch pop clips up in each corner on top rear lift cabinet by tilting forward and remove
Posted on Jul 13, 2008
Top load does wash cycle and cliks and then stops
the board that dictates the wash cycle/spin etc has malfunctioned,,you can remove top of machine and get part number/ref number from the circuit board and try to locate one on ebay or fone round yor local washing machine/electrical repair shops to see if they can either fix it or locate another circuit board for you,,,hope this helps,,,p.s. make sure machine is unplugged at mains before any examinations,,,!!!
Jul 05, 2011 | KitchenAid Washing Machines
How do i remove the lid switch on my kitchenaid washing machine?
remove the 2 hex head screws and 2 recessed phillips screws on the back side of the control pull control ahead and lift up to remove,then remove 2 bronze colored clips under the control panel,careful theres a lot of pressure on them so dont let them hit you when removing,then pull cabinet toward you,it will tip like a car hood, then unclip the connector and unscrew the 2 phillips screws that hold the lid switch in place, reverse procedure to re-install everything,please rate this if it helps you,thank you
Jul 06, 2010 | KitchenAid KAWS850L Top Load Washer
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Oct 01, 2009 | KitchenAid Washing Machines
How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Mar 10, 2008 | KitchenAid KAWS750L Top Load Washer
Kitchenaid top load washer
Have a look underneath and see if the drive belt has fallen off. If it has, check this isn't because the pulleys have failed (look for spoke failure near the hub on big pulleys), then buy a new belt. Putting the old belt back on might keep you going for a while in the interim. A.
Apr 11, 2007 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
96 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
