HOW TO FIX CONVERGENCE IC FAULT & HOW MUCH COST APPROX
My TX-47P600H REAR PROJECTION TV on startup i get a few seconds of sound no picture then a red light just under the screen flashes intermittently (3 flashes pause etc...) Is it the globe? or some other issue
  • HectorB34 Mar 01, 2009
    I have a panasonic model: PT-56WX53G that stopped turning on. I get an error code of 5 flashes along with a 5 second pause and it starts all over again. My tv is a color projection system. Anyone knows what this means?
  • 19,396 Answers
Panasonic Flashing codes:
1: ----------------- +140 v.
2: ----------------- Low DC
3: ----------------- Convergence
4: ----------------- HHS
5: ----------------- IC 4011
6: ----------------- IC 4018
3 is convergence, either one of the two convergence ICs faulty, or something else (capacitor etc.) has blown on convergence board.
Posted on Jul 13, 2008
How do I aling colors: the red and blue colors are not align making the tv look distorted.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
Jan 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Tv shows flickering pic in an ultra violet fashion
Your tv is having convergence issues, i.e the red, green and blue are not converging properly together to give a suitable picture. you will need to replace the two convergence ics (approx cost $30 a pair), they are rectangular shaped mounted on heat sink and black in color. You will also need to check if the resistors on the output pins of each ic are not open.
and finally you will need to re-focus the red and blue using the remote.
Hope this helps!
Please rate me :D
Mar 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red and green double vision
This is a convergence problem that is either poor solder connections on the convergence ICs or defective ICs. If you can solder and are comfortable working inside the set where there are ptentially dangerous high voltages present even when unplugged, you can fix this yourself.
Please let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 19, 2009 | Sony KP-EF41 41" Rear Projection...
My tv is showing a double picture in red
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Apex Digital GB4308 43" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Philips 60 rear projection hdtv looks 3D
If your red convergence controls will not remove the red in all four directions, you have a faulty convergence IC. You will need to replace both. They cost around ten dollars each. Let me know if you need anything further.
Feb 02, 2008 | Televison & Video
Will not power on
this could be a number of probs. needs to be ck'd by a tv tech can usually be repaired for a few hundred bucks suggestions..audio ic,convergence ic,signal board or power module..note these parts are pricey so trouble shoot to correct part. John
Sep 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
386 people viewed this question
Top Televison & Video Experts
