Your speaker No problem. Things can get sort of technical when it comes to solving problems correctly. Okay, on the rating I appreciate the change. You can ask for me anytime, use the find experts link on the home page, I'm usually on the second or third page. Or from here: http://www.fixya.com/users/worldvet Nice day.
  • Glenn Rogers
    Glenn Rogers Jul 15, 2008
    No sweat. Everything got sort of screwy around here over the weekend if you didn't know it. I was trying to thank a user who voted on a premium by using the Ask Me button. Howe it got to you I have no idea. But it could have happened during the database repairs.
    Sorry, but glad to meet you. See you on the boards.
    Worldvet
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
I Have a Technics PR-305 Digital piano that I have for a little over 12 years ago that I enjoy playing on very much, I have a distortion problem in my speakers it`s not very bad I was told in Fixya th
The Speakers can be replaced with any brand. The thing you need to know is the OHM rating for the speaker. OHM is also called impedance. Unless the sticker has fallen off the back of the speaker that information will be on that sticker. OHM rating MUST match the old speaker. For instance 4 OHM, 8 OHM, 16 OHM are common ratings. All different ratings but VERY important to get this correct otherwise you could damage the electronics of your instrument.
Aug 13, 2017 | Music
Have power and fuel just not enough to keep it running
There can be several causes for this problem. The first thing to check is the fuel pressure. You can borrow tools for this at most big chain autoparts stores like Autozone. If you find that the pressure is Okay, then there is a different reason for your problem.
If you need additional help, please include the Brand of vehicle and Year and Model. Sometimes a common problem for 1 car is on record and it will be helpful in problem solving.
Often things like an EGR or TPS can be part of the problem. Another condition called "Limp Home" mode can be falsely activated and produce your results. You can sort through some problems by whether they activate the "check engine" light or not as grouping things to look for.
Please rate my info.
Jan 02, 2013 | Cars & Trucks
Seems to be no power to speakers.
Disconnect green speaker jack from computer and see if you get a green power light on speakers. If the speakers indicate they have power, your sound card or circuit is shorting out the speakers. If you still have no power to the speakers when disconnected from computer, then no green light means no power to speakers. Either you’re A.C. adaptor is bad or the speakers are shorted out. You have 2 options:
1) Replace A.C. adaptor.
2) Replace speakers.
If you buy new speakers, make sure that they have their own power source (A.C. adaptor).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell A215 Computer Speakers
Filter
Hello culmer4
You wrote, the red filter light comes on but i do not use the water nor do i make ice because it is not connectrd i only yse yhe fridge to cool and freeze things what's my problem?
If you do not have the water connected then the light only went on to remind you to change the filter because of the time that lapsed since you started your fridge.
If you do not use it or need it do not change it and you are okay.
Then it means nothing to you and will not harm anything being lit.You are safe.
So your worries are solved.
Thank You Huuum
Please remember to leave a rating
Oct 25, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hey
prpbably not directed at me i trying to help solve the problems here..... lol
Jul 11, 2008 | Audio Players & Recorders
Rear Speakers do not sound, other 2 do, and boofer.
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
7949.jpgGreen connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Speakers System
7949.jpg Green connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
Hope that helps!
IrishDruid
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Mine has a sound problem. when i turn it on the sound is just set at a very low level.but after some time it abrumptly comes highy. i was suspecting dry joints but still the problem exists.i also tried...
some toshibas use an mtx module if yours is one of these take the cover off there will be a little board inside it will look dark that is your sound ic if yours is like this that should fix it
Oct 04, 2006 | Toshiba 50HX70 50" Rear Projection...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
