Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Wash Cycle Noise
It makes a humming noise during the wash cycle and there is little water comes thru the spray. The drain filter is clean. Is there anything else to check before replacing the circulating pump???
  • Vask Jul 13, 2008
    When will someone be on chat to help???
    President:
  • 1,462 Answers
You can chat with me now!
fault may be more simple than replacing the whole circ pump. it is probably the pump capacitor which is a cheap part. no need to buy as a bosch spare - you should be able to find a capacitor of the right value from a good elec spares shop. value is printed on the capacitor
Posted on Jul 18, 2008
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
Oct 20, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
DISHWASHER
faults not related i would think is there a low humming noise when supposed to be wsahing? if so this is the motor capacitor faulty in all probability. this is a cheap part and easy to replace. otherwise, check if power to pump. if no power then points to a module fault. if there is power, points to a motor fault
Jun 22, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
219 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
