Question about Haier hwr10xc6 Air Conditioner
Disconnect the wirering to clean. I donnot know how to reconnect proper.
  • 78 Answers
Obviously you dont no how to type proper
Posted on Jul 13, 2008
  • Tyler Durden
    Tyler Durden Jul 13, 2008
    just kidding. Try to reconnect to which piece fits, like, by color
Disconnect battery on 2003 nissan micra auto to clean and grease terminal, when reconnected car wont start all lights are on but wont turnover. Car was working perfect prior to disconnecting battery.
Just because lights are working does not mean you have a good enough connection to operate the starter motor. Try turning on headlamps, then try to crank it with someone looking at headlamps. If they dim badly or go out, recheck the battery terminal connections. Did you grease the areas that should make the connections? What grease did you use? Try cleaning connections with brake cleaner, sand or wire brush and reconnect without grease. If this works, grease the outside only to seal connections and prevent corrosion.
May 11, 2016 | Nissan Cars & Trucks
Srs air bag light flashing
This code is telling you of an ECS module fault.
An ECS module fault could be caused by:
- the internal accelerometer not operating properly.
- the backup power supply not operating properly.
- an internal module circuit fault detected.
- a microcontroller RAM/ROM/EEPROM fault.
Before doing any of the above, disconnect the vehicles battery and Remove the main connection off of the ECS and clean with electrical connection cleaner, then reinstall, then check the connectors and wires under the seats - these fail all the time.
After checking and cleaning reconnect battery.
Sep 26, 2015 | 1998 Ford Ranger SuperCab
Fiber optic plug does not connect
Optical fiber connectors need to be clean in order to work properly, they need some special cleaning tools, you have to ask for them at the electronic store, normally you should avoid disconnecting and reconnecting fiber optic connectors a lot.
Apr 05, 2014 | Samsung HT-Q100 System
My starter is not working properly on my 1999 Plymouth Voyager Espresso SE. I need to locate it, check connectors and possiby replace it. How do I locate it and the connectors?
its bolted into the bell housing this is at the back of the motor were the motor&tranz r mated together some starters can only be got 2 from underneath the vehicle make sure u disconnect the positive battery lead before touching the wirers on the starter
Sep 11, 2011 | Plymouth Voyager Cars & Trucks
Recently i replaced battery in my 2002 envoy, now if a/c is on it idles rough and will stall, can you help me with solving this problem
Clean your throttle body. Disconnect the battery, and take the plastic resonator and large hoses off that attach to the throttle body. Clean with throttle body cleaner, must be nice and shiny. When finished, drive around for 20 min or so, so the computer can re-learn the properly functioning throttle body. Your computer learned some bad habits with the dirty throttle body, so when you disconnect the battery and reconnect it, it thinks the throttle body is clean and functioning properly which is not the case. If you do it yourself, can cost you a can of throttle body cleaner $7.
Feb 19, 2011 | 2002 GMC Envoy
Washes until end of wash cycle and stops working before the rinse cycle. Same on all settings.
replace lid switch
where yout timer asymbley and controls are a screw in the bottom left and right corner remove and flip timer assymbley back towards wall in dead center of cabinet there is a quick disconnet for the cord disconnect the complete following steps..
there should be another quick disconect usually sitting horisontal that usual for your lid switch remove and jump across the two outside wires reconnect power and put washer on drain and spin if it starts to spin this means the switch connected to this connector is bad called a lid switch which controls the washer not to spin if the washer lid was left open this is a safety mechanism and must be replace with a new switch i donnot reccomend leaving this switch jumped out even though you could do laundry untill your part comes in.....
Jan 24, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I need a diagram to find my aluternator in my 1998 dodge strstus please.
2.0L DOHC Engine
See Figure 4
  1. Disconnect the negative battery cable.
  2. Disconnect the starter motor electrical connections.
  3. Remove the starter motor mounting bolts and remove the starter.
cb88b61.jpg Fig. Fig. 4: Exploded view of the starter motor mounting-2.0L engine
To install:
  1. Clean both surfaces of the starter motor flange and the rear plate. This is important since the starter grounds through its case and the transaxle flange to which it attached. Some remanufactured starters may have paint on these areas which should be cleaned off before installation. Install the starter motor onto the transaxle and secure with the retaining bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  2. Attach the electrical harness connectors to the starter.
  3. Connect the negative battery cable and check the starter for proper operation.
2.0L SOHC Engine With Manual Transaxle
See Figures 4 and 5
  1. Disconnect the negative battery cable from the left strut tower. The ground cable is equipped with a insulator grommet which should be placed on the stud to prevent the negative battery cable from accidentally grounding.
  2. Remove the air cleaner resonator.
  3. Remove the positive battery cable retaining nut from the starter.
  4. Disconnect the positive battery cable and alternator output wire from the starter.
  5. Disconnect the push-on solenoid connector from the starter.
  6. Remove the 2 bolts that attach the starter to the transaxle.
  7. Remove the starter from the vehicle.
Fig. Fig. 5: Starter motor wiring terminal connections-2.0L engine To install:
  1. Install the starter and the attaching bolts to the transaxle assembly.
  2. Tighten the attaching bolts to 40 ft. lbs. (54 Nm).
Clean all dirt and/or corrosion from the wire terminals before reconnecting the wiring to the solenoid.
  1. Reconnect the push-on solenoid connector to the starter.
  2. Reconnect the alternator output wire and positive battery cable to the starter and tighten the retaining nut to 90 inch lbs. (10 Nm).
  3. Install the air cleaner resonator.
  4. Reconnect the negative battery cable.
2.0L SOHC Engine With Automatic Transaxle; 2.4L Engine
See Figures 4, 5 and 6
  3. Remove the 3 bolts attaching the Transmission Control Module (TCM). Do not disconnect the TCM wiring. Move the TCM to gain access to the upper starter mounting bolt.
  4. Remove the upper starter mounting bolt.
  5. Raise and safely support the vehicle.
  6. Remove the positive battery cable nut and disconnect the cable from the starter.
  7. Disconnect the push-on solenoid connector.
  8. Remove the lower mounting bolt that attaches the starter to the transaxle.
  9. Remove the starter from the vehicle.
Fig. Fig. 6: Starter motor wiring terminal connections-2.0L SOHC engine with A/T; 2.4L engine To install:
  1. Install the starter onto the transaxle and the lower mounting bolt.
  2. Tighten the mounting bolts to 40 ft. lbs. (54 Nm).
Before reconnecting the wiring to the starter solenoid, be sure to clean the wiring of any dirt or corrosion.
  1. Reconnect the positive battery cable to the solenoid post and tighten the retaining nut to 90 inch lbs. (10 Nm).
  2. Reconnect the push-on solenoid connector.
  3. Lower the vehicle.
  4. Reinstall the upper attaching bolt and torque to 40 ft. lbs. (54 Nm).
  5. Reinstall the TCM to its original location and install the mounting screws.
  6. Reinstall the air cleaner resonator.
  7. Reconnect the negative battery cable
Hope helped.
Feb 01, 2010 | 1998 Dodge Stratus
When i am starting my pc i am getting three short beeps,i swaped working one ram with my pc ram,and also swaped in second ram slot ,problem same,i thought mousher problem also i cleaned ram ,ram slot but...
If not the RAM then it's your Video Card, try to clean it and properly connect.
For possible if still not open then put only one memory ram to make sure that the problem is taken with another parts inside.
And last try to reset the BIOS.
Nov 04, 2009 | Computers & Internet
Erratic idoling when warm
sounds like the air idle valve , if you can get hold of valve to test, try this find valve on inlet manifold and pull hose off going to throttle body,reconect hose to new valve so valves are i line to each other, start car and let it idle for a few moments till the fast idle slows down, then disconnect the wirering goint to the original aiv and connect to the new one , hopefully the original one would have been diconnected in the open position , reconnect wirering to the new valve and turn engine off. disconnect battery for 20 seconds . recon battery and turn ignition on, pump gas pedel 5 times to reset . start engine and let it idle for a few moments ,then try to turn steering wheel , engine speed should rise slightly due to load from power steering pump and then settle back down 875 1075 rpm.this is what the air idle valve should do. if it doesen't look at wiring goig to aiv might have scuffed through.
Aug 09, 2009 | 2002 Land Rover Freelander
How do I connect printer when everything is physically connected properly
1.Disconnect USB cable & reconnect it.
2.Disconnect Power cable & reconnect it.
3.Check if the driver of Z1420 is properly installed?
Apr 01, 2008 | Computers & Internet
Haier hwr10xc6 Air Conditioner Logo
23 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
