Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Im still on my knees begging for it to spin
My washer wont spin because it is upside down I think. I want it to spin what should I do?!?!?!?!?!?!!
  • spidpiglovme Jul 13, 2008
    Hey it works now thanx chad!!!
    Scholar:
  • 148 Answers
Flip it over
Posted on Jul 13, 2008
  • derek martin Jul 13, 2008
    wow that was a joke
Getting an error code of an upside down forward facing F followed by an E
i think it is a tE error code. thermistor issue. easy, cheap fix. check out appliancepartspros.com or repairclinic,com for how to videos and parts.
May 17, 2016 | LG WM-2277HW Front Load Washer
My washer will agitate but wont spin out or drain any ideas ?
No washer will spin when the lid is up. If the lid is down and it still wont spin, the first thing to check is the lid switch. If it's bad, the washer will think the lid is up all the time. You'll need to remove the front panel of the washer to see it. Here is the switch to order.
Dec 07, 2012 | GE Washing Machines
When drawing thread up from the shuttle needle wont go down
Sounds like your hook to needle timing is off. When you sew through thick materials, a lot of machines have issues where the needle sticks in the fabric but all the internal parts shift and this causes the hook to needle timing to go out. The begging signs of this is skipping stitches. You will have to have you local independent sewing store do this adjustment for you
Hope that helps :)
Chris
Jun 05, 2010 | Brother XL-2230 Mechanical Sewing Machine
Error code looks like an upside down FE
The upside down F is actually a lower case t. The fault code indicates a faulty thermistor.(temperature sensor) The first step in troubleshooting is to unplug the unit for 10 sec. plug in turn on and select rinse/spin mode and no spin option to drain the water.If this does not solve the problem you will be directed to a service company.
Apr 24, 2010 | LG WM-2277HW Front Load Washer
Toshiba satellite l305 wont recognize blank cd
A replacement CD recorder is not expensive at all. Check out fleabay listings.
Nov 10, 2017 | HP SureStore CD-Writer Plus 9150i CD-RW...
Machine washes but ont the spins it wont kick the clutch in
yep the clutch is going out you are lucky it will spin at all
Jan 13, 2009 | Whirlpool LSB6200KQ Top Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
UNLOCK BLACKBERRY 8100 FOR FREE PLEASE
I need unlock code for Black Berry 8120
Oct 04, 2008 | RIM BlackBerry Pearl 8100
My washer doesnt wanna spin
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jul 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
